Home > General Chat > Box section(cross brace) under seats
Dangerous
Member #: 417
I got an alloy cover for it that came with the car,can I use this and drill a lot of holes/cut chunks out of the steel in the car then bolt the alloy one in,or would this effect handling-shell strength etc
on this section bri i would leave well alone buddy
just my opinion
I'd agree with Steve, the cover is just that, an alloy cover to tidy it up, I wouldn't cut the crossmember out unless you are going to do something substantial to replace the strength of it.
Dangerous
Member #: 417
So if you put a multipoint cage in which is braced behind the seats,down the sills and accross the dash then you could ?
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
I wouldn't take that out even with a full weld in cage in place .... it's about all that keeps the doorsteps where they should be!
Richie
Member #: 628
second what Rodge is saying, plus steve and i will also jump on the Fenton band wagon, that box section is pretty crucial mate if you take it out and take an impact to the side of the car, the intrusion would be pretty horrific i have seen minis in side smashes where the box section has absorbed the impact and channelled it through the car, and let me tell you it makes you pretty damned nervous about being in a mini in a crash :( keep it in bro, lil bit extra weight is a small trade off for ure life *wink*
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
I got two of them in my Mini, one between the B posts and the original one. The bucket seats bolt nicely to them
I'm going to go the other way as i know what cage brian has got.
i'd say you can take it out. i've seen it done even without the re-inforcement done.
Just a thought and opinion! *smiley*
I've cut a big hole in mine to get the battery in. But I do have a tube running down each side of the car, just inside the step, and also a spine down the middle.
Mini_Andy
Member #: 432
bri are you sure its alloy plate, the previous owner like to bodge thing and although i never actually checked, i assumed it was wallpaper LOL
