Home > General Chat > Timing beams on 1/4 mile track
Does anyone know how high off the ground the beam at the finish line is?
Paul
I'm guessing it's going be mm's as leaves can often set it often.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Normally the staging beams are broken by the wheels and the beam at the end of the track is broken by the font of the car. Of course that doesn't really help but it must be higher up than the wheels I guess. So if you had a car with A LOT of overhang...
On 7th Nov, 2008 Nic said:
naeJ
m
Id have thought the beams would all be the same....
Why would the ones at the top end of the track be different to all the rest ?
Id say the beams are circa 3"off the ground.
They can clearly be seen when at Santa pod etc
Jay#2
Member #: 648
I remember someone in Oz decided on using a Plymouth Superbird as a basis for a drag car just because of the large overhang the nose cone gives. That plus the massive wing!
naeJ
m
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Seems abit daft...why don't they do timing like hillclimbs etc. Transponder would be too expensive for joe public
On 19th Jan, 2010 wil_h said:
I cant see how having a large overhang on the front of the car helps with times. You still start from the same position, unless your inspector gadget and your car increases in length at the touch of a button!
I think the theory is mike that the start is measured from the wheels, so any front over hange is subtracted from the 1/4 mile distance (if that's how it works).
I always asumed that it was the same at the start and fininh i.e. on the wheels. Otherwise it'd be daft.
Paul
Just how tall is this next sprint going to be?
Nic, nothing to do with my car.......I just wondered how much shorter the track is for cars with a front splitter like the DON.
Its around 10". Can any clever maths bods work out how long it takes to cover 10" at 105mph?
Paul
stefaz
Member #: 1656
stoke-on-trent
0.064935 secs
ah, so that is 3/8 of fuck all then....
Its still something.............. Im fitting a splitter
Paul
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Having a splitter 2 metres in front of the car might be taking the piss! :)
I was only thinking 3 foot. lol
Paul
Don't be silly.
I'm sure that the device thats starts the timing is at the same height as the one at the end.
So it makes no difference.
the same part of the car breaks the beam at both ends of the track, so it matters nothing what you have in front of the wheels,
At the start line theres a beam in front and behind the wheels which give the staging lights...........so Im led to believe by an ex pro drag bike champion. At the other end its the first part of the car to break the beam be it the wheels, valance splitter or rear number plate.
Paul
http://www.musclecarclub.com/library/race/...s.shtml#staging
read !!.
i know all of this already btw,lol
It says in there its the wheels that break the start line beam
Paul
chinlesswonder
Member #: 1192
In the garage......again!!
Never run on a drag strip myself but was wondering, does the timer start as soon as the lights go green?.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
No, not until you leave the start line.
Paul
chinlesswonder
Member #: 1192
ahh, that must make the nerves settle a bit then.
Paul
its whichever part of your car that blocks the light,
they are being general assuming we all run big yank tanks,
carl
Jay#2
Member #: 648
Yay! Someone believes me! I know in most of the tracks in OZ it's as Paul says, it's the first part of the car that breaks the beam on the finishing line, not necisarily the wheels (I think this beam is a little higher). On staging it's the wheels meaning in theory an overhang gives an advantange.
Paul
naeJ
m
