| Home > Help Needed / General Tech Chat > Does an M9 bolt size exist? | |||||||
4th Sep, 2007 at 08:24:04pm
I just managed to strip the thread on the nut that holds the rear subframe to the heal board/sill box section end.
4th Sep, 2007 at 08:32:47pm
5/16th unf i believe it is
Edited by Nic on 4th Sep, 2007. |
4th Sep, 2007 at 08:36:34pm
Tap and helicoil?
4th Sep, 2007 at 08:39:26pm
On second thought I didn't consider helicoiling it. Would that be a feasable option?
4th Sep, 2007 at 08:41:43pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=140149259492
4th Sep, 2007 at 08:45:09pm
9mm does not exist per say, but are available from very specialised suppliers, in 1.25 mm pitch, you can buy a 9mm tap though . it is not classed as M9 , but 9mm fine, only the M should be applied to the standard metric threads, my old pal Norman reaslly has a big bug about this topic,
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
4th Sep, 2007 at 09:01:36pm
They are usually used on newer cars, vaulxhalls have this thread on their calipers. Back once again like a renegade master |
4th Sep, 2007 at 09:12:39pm
I think you mean they need 9mm allen key. The only size thats never in a set!
On 4th of Sep, 2007 at 09:01pm minimadj said:
They are usually used on newer cars, vaulxhalls have this thread on their calipers. Edited by Jason G on 4th Sep, 2007. On 19th Jan, 2010 wil_h said:
4th Sep, 2007 at 09:15:18pm
Drill it out and put a rivnut in,the thread will then be behind the nut that is in there so can't go anywhere
4th Sep, 2007 at 09:20:13pm
[quote=milamber,4th of Sep, 2007 at 09:12pm]I think you mean they need 9mm allen key. The only size thats never in a set!
4th Sep, 2007 at 10:05:32pm
On 4th of Sep, 2007 at 09:20pm minimadj said: On 4th of Sep, 2007 at 09:12pm milamber said:
I think you mean they need 9mm allen key. The only size thats never in a set! No theyre m9 1.25 thread on the adjusters. I know it sounds mad but we had to re thread one yesterday. this was the point i was trying to make, it is vehicle manufactureres that introduced thesae bastard sizes for obvious reasons, and they decided to call them "M" whatever,. whioch they shouldn't have done , they should have just refered to them as metric fine. carl |
4th Sep, 2007 at 10:15:04pm
If you put a metric thread on a Mini you might as well fit a BMW badge at the same time On 5th Sep, 2011 Vegard said:
4th Sep, 2007 at 10:16:23pm
I agree. Like m10 fine which is either 1.00 or 1.25.
4th Sep, 2007 at 10:37:43pm
On 4th of Sep, 2007 at 10:15pm Scruffy said:
If you put a metric thread on a Mini you might as well fit a BMW badge at the same time LOL Well thats all the 1992 onwards Minis bolloxed then
Edited by Sprocket on 4th Sep, 2007. On 26th Oct, 2004 TurboDave16v said:
4th Sep, 2007 at 10:42:51pm
http://www.engineeringtoolbox.com/metric-threads-d_777.html On 26th Oct, 2004 TurboDave16v said:
5th Sep, 2007 at 12:30:43am
M9 is an absolute bastard thread. Drill out and weld in new 5/16 UNF to do a proper job.
5th Sep, 2007 at 08:08:32am
If you put a metric thread on a Mini you might as well fit a BMW badge at the same time The spark plug thread is metric,so thats 4 you got allready:$
5th Sep, 2007 at 03:45:37pm
89 on on had metric fittings on things like the brake servo, just to be pedantic lol :) Edited by t3gav on 5th Sep, 2007. |
5th Sep, 2007 at 06:12:05pm
I often open many holes out to suit an M8 (5/16 is 7.9375mm), M10 (3/8 9.525mm) or M12 (7/16 11.1125).
5th Sep, 2007 at 06:47:20pm
On 5th of Sep, 2007 at 06:12pm RogerM said:
I often open many holes out to suit an M8 (5/16 is 7.9375mm), M10 (3/8 9.525mm) or M12 (7/16 11.1125). Getting imperial bolts, especially in a good grade around here is almost impossible (unless you remortgage!!!) Nothing wrong with metric stuff, and it's cheap!!! I'd not change anything threaded (like the heal board) from imperial though as it's bound to cause you a problem when you need to get a replacement for whatever reason and you forget you changed it to metric ...... unless you can readily identify metric and imperial threads at a glance. Edited by fastcarl on 5th Sep, 2007. |
5th Sep, 2007 at 08:58:41pm
The Magic circle??
