Home > Help Needed / General Tech Chat > does my compression ratio calculation look right
Carl
Member #: 95
liverpool-on-sea
ok ive just measured and worked out, just looking for some clarification (sp?) that im not a million miles away with my measurements or calculation
spec
+0.020 thou overbore to make 1293cc.
18cc dished pistons
bk450 gasket
standard head
measurements
head chamber 22.5cc
stroke 82.35mm
bore 70.90mm
piston dish 18cc
top of piston to top of block 0.85mm
head gasket bore 70.90mm
head gasket thickness 1.03mm
i get 7.74;1
is it looking right?
thanks in advance
Edited by Carl on 5th Sep, 2007.
your calculations work out ok,
but isn't + 20 71.15mm and std stroke 81.33mm
Yeah I would re-check bore/stroke values..
Carl
Member #: 95
liverpool-on-sea
hmmm stil turns out at 7.7;1 seems a little low so not sure if its right.
Using standard stroke and 71.1 as bore I make you CR to be 7.82:1. :)
So looks like your on the right tracks.
one reason its low is the deck height, .82 is about 3 1/4 cc
on a properly decked build you'd be up to about 8.2:1
My thoughts exactly... *wink* The lower CR just means you can run more boost..lol
Carl
Member #: 95
liverpool-on-sea
is the deck hight from top of piston to block with the piston at the top?
these are avonbar/accralite pistons so perhaps they sit a little lower down the bore?
the block had a very light skim as well on the build
IIRC the accralite do sit slightly further down the bore...stand to be corrected though?
Carl
Member #: 95
liverpool-on-sea
well thnks for the help.
my measurements may not be spot on but even if i use the figures what ive found on here i can deduce my compression ratio is some where between 7.7;1 and 8.0;1 i think lol
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
I cant believe youve only just bovered. LOL
Seems lower than i thought it wouldve been.
Saying that youve ran some stupid boost wit no gasket troubles (until now)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
http://www.afracing.com/cr.xls
Edited by AlexF2003 on 6th Sep, 2007.
AlexF
