Home > Help Needed / General Tech Chat > new holes in subframe
stevecoolerking
Member #: 155
i know some people have mentioned this before, but i cant find the posts, (sorry)
avonbar recomend drilling new holes in the subframe just forward of the original ones (but only if your car is not an injection model) this all sounds a bit potchy is it really necessary ?
and is really necessary buy new engine steadys cant i just use all the original stuff from my cooper ?
dont bother, i never have and not had a single problem *smiley*
i did not bother either but then my cars not been used yet
SumpNut
Member #: 28
I have run my engine on the standard holes with no probs - wouldnt bother moving it forwards as its tight enough at the front anyway
clubman_dan
Member #: 142
Winchester
what about in a clubman?
Gibbo
Member #: 34
You'll end up running a T2 and a intercooler, so don't bother re-drilling!
Yeah space at the front is much better than at the back. there is plenty of room with correct bulkhead mods with std hole mounts.
stevecoolerking
Member #: 155
cheers guys !
what about extra engine steadys are they necessary? can i just use the ones i got with my cooper engine ?
extra engine steadies are worth while, you need to make your own bracket for the thermostat side as you cut out the mounting bolts when you put the bulkhead box in
Edited by iain on 15th Jun, 2004.
