Home > Help Needed / General Tech Chat > O/T Superchargers
how do you work out what size and manufacturer is best for the size of engine? do you get a compressor map for a supercharger like you do turbo's ?
do eaton make bigger chargers than the 45 for a 2.2 - 2.5 engine
pretty sure you do.....although as always, some maps are harder to find than others.
There are Eaton/Rootes style for many big engines, so a 2.2-2.5 shouldnt be a problem ?
Many V6 and V8's out there with them...
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Look at the big mercs.
Supercharger prices have gone crazy on the bay just lately ...... might be worth ringing round the breakers.
There are some supercharger maps here http://www.rbracing-rsr.com/turbotech.html to give you an idea.
Neil, An Eaton M90 is a pretty easy blower to get hold of, and on a 2.5l with a 6500rpm limit will do a little over 13psi at 12K rpm blower speed.
On a 2.2l, and same revs, it'd make 17psi, which is actually higher than you'd really want to run an Eaton as its well out of the efficiency band. A 1.7 drive ratio (11K rpm blower speed) would be a little over 14psi, which is much more like it.
If you need help sourcing an M90, let me know *wink*
here's a blower calculator thingy,
handy for the speeds and pully ratios
http://www.sprintex.com.au/Opcon_Autorotor.asp
thanks dave thats a great help
dont suppose you know the dimensions of the m90?
danboy
Member #: 1381
Woolfie, The eaton blower range is numbered by the displacement per revolution.
ie M45 displaces 45cu in. per rev
M62 displaces 62 cu in. per rev.
http://www.rbracing-rsr.com/turbosupermaps.html
this link may help, the info is down towards the end of the page.
Hope this helps.
Regards
dave
Ric
Member #: 36
Basingstoke
Neil, i seem to remember you saying at avon 06 that superchargers were for girls? *wink*
only in golfs
Ric
Member #: 36
Basingstoke
i thought that might be the case. *wink*
so, what are you blowing neil?
*wink*
stefaz
Member #: 1656
stoke-on-trent
quote gold
Mini_Andy
Member #: 432
something to do with scooby doo..............
Ric
Member #: 36
Basingstoke
2 sig'd quotes in a day, i'm honoured. *wink*
sarah michelle geller ??!!!,neil you lucky bastardo !!!!
i wish ... recon shes a bit filthy *wink*
with the size of the engine bay on the camper ive been thinking of supercharging the scoobydoo lump i have for it
long way off .. poss early next year do to my current finances but just want to look at the possibilitys, ive also been thinking of the svx lump but fuel economy and rarety may prohibit this
Jay#2
Member #: 648
Northern Ireland (ex AUS)
SVX flat six with the slush box and 4WD running gear, now that is an idea!
On 7th Nov, 2008 Nic said:
naeJ
m
