| Home > Help Needed / General Tech Chat > Air filter ducting suitablility | |||||||
249 Posts Member #: 513 Senior Member Sheffield |
12th Sep, 2007 at 07:35:55pm
Just about to order an air filter and ducting. Merlin do a;
12th Sep, 2007 at 08:13:08pm
I've used the black stuff before and going to use it again on Candice's build.
12th Sep, 2007 at 09:41:23pm
Will the silicon collapse if kinked? Just bolted the rad down and dropped the turbo/manifold assembly in but it looks like the air filter pipe will foul the timing cover and the bottom hose. Heres a (poor) pic of what I'm talking about. Looks like it would probably squeeze in but will it be ok?
Edited by andygardner on 12th Sep, 2007. |
12th Sep, 2007 at 09:41:56pm
double post. Edited by andygardner on 12th Sep, 2007. |
12th Sep, 2007 at 09:52:01pm
Would not of hurt to have cut a bit more of an angle on the edge of the bulkhead box but a bit late now I guess.
12th Sep, 2007 at 11:51:46pm
Yea should have beveled that corner. Good thinking on the solid silicon though, Have to see if I can get a piece to go 90º horizontal towards the bulkhead then turning 90º upwards, Cheers. |
13th Sep, 2007 at 06:39:56pm
To save opening a new thread, I measure the plenum and turbo 'out' to be 48mm will 45mm silicon stretch over this or should i go with 51mm? |
13th Sep, 2007 at 06:53:38pm
Think the 45 may just go. Think all mine was 51 though ..... been a long time. Every day is a school day ...........
