| Home > Help Needed / General Tech Chat > MPI Rad requrie MPI hoses?? | |||||||
1171 Posts Member #: 107 Post Whore Sunny Sussex |
13th Sep, 2007 at 10:50:07am
I plan to use my MPI rad, but do i HAVE to use the MPI hoses or can I use a set of SPI instead - not sure what the differences are.
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
13th Sep, 2007 at 11:16:54am
the location the rad sits in!!
13th Sep, 2007 at 11:18:07am
SPI has a side rad & MPI has a front rad, so the hoses are totally different as the rads are in different locations. Also the MPI has a separate expansion tank where as all other minis have room for expansion built into the top of the rad, and to be a real bitch the MPI thermostat housing (which you need if you want to use the MPI top hose) is totally different to any other thermostat housing, not only that but nobody makes them (although several companies list them in there catalogues when you phone them they do have any, grr, it took me months to track down mine as most MPI breakers want to sell them with the head).
Edited by Rob H on 13th Sep, 2007. Isambard Kingdom Brunel said:
13th Sep, 2007 at 11:43:09am
ffs forgot the spi was side mounted. knob
397 Posts Member #: 694 Senior Member Shropshire |
14th Sep, 2007 at 10:27:49am
Unless you want your engine bay to look as if it had the MPI rad from the factory, I would strongly suggest buying some nice silicon hoses & alloy tube and using them to make your water pipes, as you would with a custom rad install.
14th Sep, 2007 at 02:32:31pm
cheers stig, i checked minispares initially and thier bottom hose was over £115. I just checked Minisport as you said and they are £29, subtle difference! All ordered - many thx again for the input :)
