| Home > Technical Chat > warning odd idea.. using the third cam on a bimmer | |||||||
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
13th Sep, 2007 at 06:01:29pm
13th Sep, 2007 at 06:06:41pm
how would this help the crank?
450 Posts Member #: 449 Senior Member Oxford |
13th Sep, 2007 at 06:15:20pm
nice idea but the first thing most people do with engines with a balance shaft in is to remove the balance shaft to reduce rotating mass. Not a bad idea for a road car for everyday use though. |
13th Sep, 2007 at 06:16:12pm
I would have thought the mathematics involved would be well out of the scope of the amature engine builder.
14th Sep, 2007 at 07:50:16am
MMM I like.. Good idea. Dave, fix it! On 13th Jul, 2012 Ben H said:
14th Sep, 2007 at 08:46:30am
pardon me, but to remove higher order unbalance the shaft would have to go double the speed or even four times the speed, the crank goes half the speed...
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
14th Sep, 2007 at 09:48:45am
Honda use balancer shafts.The principle is old.Think its called a Lanchester balancer,runs at twice crank speed. 'Where does the engine go?' |
14th Sep, 2007 at 09:54:18am
On 14th of Sep, 2007 at 08:46am miniminor63 said:
pardon me, but to remove higher order unbalance the shaft would have to go double the speed or even four times the speed, the crank goes half the speed... I think I am right on this one? Change the sprockets then, and modify the oil pump. Try seeing solutions Andrè
14th Sep, 2007 at 10:03:52am
Just checked this,Mercedes also use it,but Lanchester were first in 1911.Even before my time.You need 2 contra rotating shafts running twice crank speed.The weights cancel each other at one point in the cycle,but provide a counter balance at the right moment. 'Where does the engine go?' |
14th Sep, 2007 at 10:22:27am
yes thats what I seem to remember from combustion engine class steve. I think this may prove very difficult to do tbh.... |
14th Sep, 2007 at 11:50:18am
I thought the balance shaft rotated the opposite direction to the crank
14th Sep, 2007 at 12:14:48pm
And how would it fit through the cam bearings if it had balance weights attached?
14th Sep, 2007 at 12:24:24pm
nice point, and there is not much space around the cam for the counterweigths, its already troublesome when you fit an 8 porter (cam hits rods). I am not too sure about how the bearings would tackle double the speed and more weight either... Edited by miniminor63 on 14th Sep, 2007. |
14th Sep, 2007 at 12:35:39pm
The bearings would live. One should be led to believe that a balancer was infact balanced On 13th Jul, 2012 Ben H said:
14th Sep, 2007 at 12:37:46pm
it would have the same imbalance as the thing its supposed to balance out, just opposite.... |
