Home > General Chat > turbo engine vs na mg metro engine??
JT
Member #: 637
Hertfordshire
hi
im just wondering how much differnce there would be in the following engines.
a turbo engine running 7psi all the time with a t3 and a 3.1 final drive, and a standerd mg metro engine but with a 3.1 final drive.
would there be alot of differnce in performance and drivability?
would they be about as reliable as each other?
i ask this because im thinking of making my na mg metro lump which im going to stick in my runaround once iv rebuilt the box, to a more or less standerd turbo engine.
what do you guys think?
cheers
josh
My build thread..
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Much more low down torque and about 20-25 more banannas from the turbo.
I think turbo's make the best road engines in a Mini, especially as they make short work of a 2.9 / 2.7 final drive!
I moderate boost, high CR turbo lump will be great to drive on a daily basis.
JT
Member #: 637
Hertfordshire
i think i might have to live with my 998 lump for a bit longer then and collect a few basic bits to convert my mg lump to a turbo one!
should i go for a 2.9 or a 3.1 final drive then?
iv got a 3.1 fd in my sccr box waiting to go on the project mini.
iv also got a 3.1 fd in a spare box and a 3.44 in another spare box, it makes sence to me to use a 3.1 as i already have one? or would it make it much nicer to drive with a 2.95? i have 10" wheels
im going to get the cr down to standerd turbo spec and maybe just use the phase 2 cam as i have one in the shed doing nothing.
i dont want to spend to much on this build as im still building another mini as a fully blown flying machine! (thats the plan anyway lol!!)
iv done a search and the only thing i need to do to the actal engine is to get the cr down by opening up the chambers? pistons etc should be able to cope?
i know about the other bits like turbo carb, return fuel lines, bulkheadbox etc etc
sorry for all the questions but im realy liking the idea of a low blow turbo runaround mini!!
cheers
josh
My build thread..
RogerM
Member #: 1217
3.1 will be ok, 2.9 better on the motorways etc. Like so much else depends on what your going to use the car for most!
On 13th of Sep, 2007 at 06:25pm josh_tacon said:
hi
cheers
josh
Having owned both a stock Metty Turbo & a stock MG Metro, the Turbo was far more responsive, more relaxed cruising and all round better engine. I must have done 20K+ miles in the Turbo and the only problem I had with it was the water pump packing in.
Still regret selling the turbo, and I'm sure I will be beating myself up about on Saturday when I go down Combe.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Metro challenge cars only run 5psi...if thats any gauge in performance. *wink*
Shall see you at Combe Rob.
Edited by Jason G on 13th Sep, 2007.
On 19th Jan, 2010 wil_h said:
JT
Member #: 637
Hertfordshire
iv decided!!
im going to do it but im not going to take any bits iv already got for the project! lol apart from the phase 2 cam.
just so i can sort out what i want my chmabers in the head to be, what size dish does a mg metro pistons have? and what cr is a standerd turbo lump? 9.4:1 isent it?
cheers
josh
My build thread..
my thoughts are the same as rogers and roh H
the metro challange cars what that jon flan and his fellow guys run is..... 8 psi
JT
Member #: 637
Hertfordshire
steve i will be in touch soonish about sorting my head out and maybe a manifold or two!
ill email you when i know what im actoly doing.
what cr should i get it down to? 9.0:1 so its a bit more aceptable to slightly higher boost? and what dish does the mg pistons have (non turbo)
cheers
josh
My build thread..
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I quote from regs....The actuator setting is 5.0psi for 0.015" (0.38mm) of actuator rod movement.
Must admit, there might be more to the measurements that I'm aware of. :(
AL
Member #: 1347
Croydon (South London)
mg pistons dont have much dish at all. got a block minus head in my hall but cant be arsed to measure. at most id say 8cc. CR was around 10:1 IIRC
