| Home > Technical Chat > Gearbox Builders | |||||||
![]() 143 Posts Member #: 1506 Advanced Member Cheshire |
13th Sep, 2007 at 09:43:25pm
Who would you recommend to build me a decent gearbox? I am building a track day car so was thinking of a straightcut gearset.
Check out the (slow) progress at.......
13th Sep, 2007 at 09:51:02pm
I think you should buy a minispares kit and give it to hogster to build, he seems to do good work and are on here.(I have not used him myself) |
13th Sep, 2007 at 10:02:24pm
agreed with miniminor63
13th Sep, 2007 at 11:48:22pm
TranX kit from Min-Its every time till the point you need a dog box then the MED set don't think you need a £1200 dog box by the way!!!) Every day is a school day ...........
13th Sep, 2007 at 11:53:34pm
If you want to build it yourself, I can give you a hand, dont forget im only round the corner. They are not that complicated really once youve had one or two apart.
14th Sep, 2007 at 06:47:04am
Thanks guys.
14th Sep, 2007 at 06:11:56pm
It'll be fine, just need decent box to start with. I have a selection of shims and shim steel as well so thats not an issue.
15th Sep, 2007 at 07:14:37am
if you can get a tans x kit then there are better than the clubman set as 2nd and 3rd gear are easyier to install.
![]() 6753 Posts Member #: 828 Post Whore uranus |
15th Sep, 2007 at 08:10:10am
On 15th of Sep, 2007 at 07:14am turbo hogster said:
if you can get a tans x kit then there are better than the clubman set as 2nd and 3rd gear are easyier to install. good luck with the build, and im sure mini sproket will soon get it to top notch status for you. why is that hoggy ? how are they different ,you made me even happier i got a tranx set lol Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
15th Sep, 2007 at 04:53:21pm
because the finish on them two gears iss better as the hole on the cone has a bigger hole in it, so making it easier to push in the plungers on the main shaft. always looking for them bigger bunches of bannanas |
15th Sep, 2007 at 08:10:37pm
tranX, is that the same as the EVO kit on msc? or is the old original tranX kit still available? |
15th Sep, 2007 at 09:49:01pm
Didn't Tran-X both produce the Clubman and the ST set for Minispares previously?
16th Sep, 2007 at 07:21:44am
the rans x kit comes with first and reverse , well it use to the one wolfie had did any way, weres the evo kit uses the old first and reverse always looking for them bigger bunches of bannanas |
16th Sep, 2007 at 12:30:41pm
the EVO or ST kit from minispares come with reverse and first gear. The clubman kit from minispares comes without |
17th Sep, 2007 at 05:27:41pm
Thanks for all the input. It was an interesting weekend...
Edited by dn89mini on 17th Sep, 2007. Check out the (slow) progress at.......
17th Sep, 2007 at 06:27:29pm
hoggy built mine using tran-x gears
17th Sep, 2007 at 07:20:28pm
i thought the ST kit was Jacknight?
My build thread..
17th Sep, 2007 at 10:30:54pm
its not JKD. I have it in my box. |
17th Sep, 2007 at 10:46:26pm
st gear kit uses new 1st and reverse and the evo clubman set uses old 1st and reverse. always looking for them bigger bunches of bannanas |
18th Sep, 2007 at 08:29:37am
yes you are right. When I bought my gearkit 4-5 years ago they where all under the brand evolution. Then they where named clubman and ST. guess that has changed. |
18th Sep, 2007 at 08:12:19pm
so whats the differnce between the ST kit and jacknights kit then?
My build thread..
19th Sep, 2007 at 05:12:31am
to be fair jk done several different ratios including the metro challenge so take your pick always looking for them bigger bunches of bannanas |
19th Sep, 2007 at 07:57:59am
I guess the difference is who produced the gearsets at least. That said I think Carl Austin have used ST and JK parts together without troubles. One are advised not to though. |
