| Home > General Chat > If you ran 105 octane fuel | |||||||
274 Posts Member #: 1174 Senior Member Sunny Southern California, USA |
14th Sep, 2007 at 02:09:15am
What kind of boost do you think you could safely run on an intercooled but otherwise stock metro turbo motor if you ran 105 octane?
Edited by Lance Link on 14th Sep, 2007. 61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
14th Sep, 2007 at 08:40:50am
i tried 113 octane and it did make it run nicer. but it was 3 times the price of optimax, and due to the cost i didnt get chance to tune the car properly to run it and as such made no difference to performance. |
14th Sep, 2007 at 11:09:33am
About 1psi pre octane point iirc...
AlexF |
14th Sep, 2007 at 11:11:15am
What about that octane boost additive crap?? Maybe it would be worth looking into, for drag use ect. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
14th Sep, 2007 at 11:34:01am
only if you set your car up for the drag stip.. ie modify the ign and the boost. AlexF |
14th Sep, 2007 at 11:49:32am
so if it's 1psi per RON, then with 105 RON you could in theory run 15psi on a standard metro.
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
14th Sep, 2007 at 01:37:42pm
OK, from my notebook.
Bugger off, I'm getting there. |
14th Sep, 2007 at 01:43:34pm
My mate used 105 stuff in his rally car, and that smells of thinners (its called 'nocar' iirc?)
14th Sep, 2007 at 05:54:50pm
http://www.team.net/sol/tech/octane_b.html On 26th Oct, 2004 TurboDave16v said:
14th Sep, 2007 at 10:44:37pm
Thanks for the info. The normal high octane fuel around here is 91 octane. So if I run 100, I'm actually upping the boost by 9 octane. So if it runs properly at 7psi with the 91 octane fuel, it sounds like I could increase the boost for short periods by up to 9psi.
15th Sep, 2007 at 01:08:45am
567 Posts Member #: 102 Post Whore Pennsylvania USA |
15th Sep, 2007 at 03:16:55am
I run Sunoco race fuel, smells pretty nice. |
16th Sep, 2007 at 05:13:51am
Yep, (RON+MON)/2.
On 15th of Sep, 2007 at 01:08am Turbo Tel said:
91 is the best in CA? didn't know that.. its 93 here on the east coast. Dont forget that US octane numbers are not the same as UK octane. US uses R+M/2 UK uses RON the end result is that 91 octane US is something around 95 UK.. 61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
16th Sep, 2007 at 03:15:33pm
On 16th of Sep, 2007 at 05:13am Lance Link said:
You should be able to get 94 at Sunoco, unless they stopped selling it in the 4 years since I lived in PA. They did!! 93 is the best now....and I have started noticing recently that some are also only selling 92. website:- http://www.terryhunt.co.uk
