Home > Help Needed / General Tech Chat > Back on the breathers again
b12
Member #: 247
Kent/Surrey Borders
I always bang on about this ...
I have just one , Vented to Atsmosphere with a little KN filter ...
Found this on the NET ,,, is it right ?
The crank case ventilation pipes need to be ventilated to the inlet manifold, this keeps the pressure below the pistons constant with boost pressure and avoids oil/charge getting pushed passed the piston rings. The inlet manifold is already plumbed for this job so it shouldn't to that difficult to do.
TurboLessTosser
Vent to atmosphere i say, if the rings are good there shouldnt be any blow by so the crankcase shouldnt be pressurised anyway. risk pushing oil out of other seals in my opinion, probably wrong though!
Im just venting all mine to air, and next time to a catch tank.
Agree with Iain.
More Internet bulls1t...
Is it on a forum like this, or some 'experts' own site?
Woohoo! I am learning stuff! *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Vent to atmosphere...
the more boost you run the better your rings seal anyway!!!
alex
AlexF
fireman-sam
Member #: 301
if you vent in to the inlet there is an anti backfire valve in the manifold and as the engine comes on boost it shuts and thats why there is a pipe to the air filter as well witch tees off from that funnie red thing so on boost you vent in to the air in take pipe
evolotion
Member #: 83
Glasgow, Scotland
is that not an anti-run-on valve?
Denis O'Brien.
dan
Member #: 93
anti run on valve is the little cylinder thing off to the side of the carb on the bulkhead with a pipe from it to the carb
i think it is anyway?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
your correect dan...
anti run on is for... well anti run on after you turn the key off.
alex
AlexF
jamesfawcett
Member #: 218
Bingley, West Yorkshire
think sams refering to the splitter thats inline with the breathers, in it are some restricting gauses to the inlet, thats waht confused me when taking it out of the metro remember!
