Home > Help Needed / General Tech Chat > Radiator bracket/cowl bolt
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Recently, due to bad engine harmonics and 2 not-just-quite-round wheels, my mini has been shrugging off nuts and bolts at an alarming rate! The latest victim was the bolt from the radiator bracket into the cowl (actually there's two but the other one is long gone). Minispares has the bushes and sleeves:
http://www.minispares.com/Product.aspx?pid=34977
http://www.minispares.com/Product.aspx?pid=32724
but they don't list any bolt other than:
http://www.minispares.com/Product.aspx?pid=35499
but I'm nearly sure it's not the right one. Since mine came off, bounced off the road then off the Megan driving behind me I have nothing to compare it to. Does anyone know what thread it is or have a part number?
Thanks!
Edited by Jay#2 on 16th Sep, 2007.
On 7th Nov, 2008 Nic said:
naeJ
m
Is this what you need?
graemec
Member #: 1424
Carnforth, Lancs
I use the grommets shown and a standard, short bolt with some oversize washers. that are about the size of the OD of the grommet.
The bolt you show on MS will not go through those grommets.
You just need a 1/4 UNF bolt, 3/4 or 1" long. Job done.
Jay#2
Member #: 648
Grand, thanks guys. I'll vist my bolt supplier this week.
naeJ
m
