Home > Help Needed / General Tech Chat > Air filter position (pic added)
i have searched through about airfilters but not found what i was really after. where do people place their airfilters? pictures would be helpfull.
i was thinking about moving my wiper motor inside the car (if it is posible) and haveing the airfilter going to where the wiper motor is and having venting in the bonnet to feed it with air.
has anyone done this? would it be posible?
paul.
Edited by Paul R on 19th Sep, 2007.
Wherever it will fit......
Avonbar green filter just the ticket flows 240 bhp worth
have a look at my position wiper motor need not be moved
heres my vents .... each to their own
cheers but i was meaning would i be able to move the wipermotor so i can have the air filter where it used to sit so i can use a air feed to it :)
like this very rough paint shop
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Can put wiper motor inside the cabin ... a bit of a faff but seen it done plenty of times.
I'd prefer to put the filter at the front though ... less messing about ... so long as you have spake of course.
MarkGTT
Member #: 1194
Shropshire.
Im with Roger, stick it at the front if you have space.
here's how ive done mine.
Edited by MarkGTT on 19th Sep, 2007.
RogerM
Member #: 1217
Is there such a thing as having too much cooling ...... don't know about a Clubman front ...... looks like that lot would need a Hummer front...LOL
Well done for craming all that in so neatly!!!!
Just one thing to have caution over and that is the oil cooler ... make sure the lowest point of the outlets are above the highest point of the core (if you catch my drift) or else you might find you get problems with maintaining pressure. Had a friend who's car we just couldn't get consitent oil pressure on and it turned out to be a vapour lock in his cooler.
Edited by RogerM on 19th Sep, 2007.
ERA mini airbox sits in the wing like that...
http://www.eraturbo.com/technical/page1/i05.png
http://www.eraturbo.com/technical/page1/i06.png
Ignore the condition of it.....car is in a bad state now. It uses the likes of a XR3i panel filter.
ive done like your thinking
well i will do when i get round to ducting it
Turbo Shed
Member #: 30
Epsom, Surrey
my filters under the pasenger side wing and gets its air via a vent in the A panel so as to keep intake temperaturs as low as possible
Done the same, mainly because of space, but the air should be cooler under the wing. *wink*
Only problem with it is that you need to clean the filter more often, especially after wet muddy mini shows...*laughing*
do you have a picture mate of your engine bay i could have a gander at please :). im not sure i would have enough room to have a filter at the front, but the way i was seeing it is that i can section the filter off away from the heat of the engine, well thats the plan
