| Home > Technical Chat > sump gaskets | |||||||
19th Sep, 2007 at 08:25:31pm
Anyone running without the gaskets between the block and gearbox?
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
19th Sep, 2007 at 09:29:46pm
I wouldnt, in fact id pour gasket sealer over it as well as gaskets. Back once again like a renegade master |
19th Sep, 2007 at 09:32:08pm
I have been using the copper gaskets from Keith Calver, they have worked fine for me. They are more like a shim than a gasket. |
19th Sep, 2007 at 09:33:51pm
i've just used normal paper ones and wellseal
19th Sep, 2007 at 09:41:51pm
The copper gaskets work a treat but I can not bring myself to spend any money with KC as he'd only spend it on having his ego inflated further .... Every day is a school day ...........
19th Sep, 2007 at 11:16:25pm
I intened to give this a go as it closes up the clearance on the drop gears (need to be sure its not too tight On 26th Oct, 2004 TurboDave16v said:
20th Sep, 2007 at 12:41:55am
Im not in my 1380 na
20th Sep, 2007 at 02:25:54am
Always found it a bit odd that there is an o ring, a gasket and sealant all doing the same job :-
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
20th Sep, 2007 at 03:11:11am
I just use sealant. no gasket, no problems On 15th May, 2009 TurboDave said:
20th Sep, 2007 at 07:40:55am
The copper sheet I use is 150um shim material by the way. Every day is a school day ...........
20th Sep, 2007 at 08:32:43am
mine only has sealant and it doesnt leak from here. it leaks from every were else but thats to protect the floor pan from rusting! |
20th Sep, 2007 at 10:00:29am
Thank's for the replies, sound comment as usual.
20th Sep, 2007 at 07:34:12pm
Just out of interest where are you guys buying Wellseal from? Never seen it!!!! Every day is a school day ...........
20th Sep, 2007 at 07:57:55pm
My machinist uses nothing else. He also put me on to Rocol Dry Molly Paste as well for assembly On 26th Oct, 2004 TurboDave16v said:
20th Sep, 2007 at 08:00:41pm
Get rid of your silly sig and I will tell you!!
