| Home > Help Needed / General Tech Chat > setting the timing | |||||||
141 Posts Member #: 162 Advanced Member |
16th Jun, 2004 at 10:32:22pm
i need to set my timing up right, it is returded so i need to advance it to about 8 i believe. when i turn the dizzy clock wise i get stoped by the module hitting the starter moter. what can i do to solve this problem with out taking the drive out of the engine. as i have heard it can drop into the gearbox |
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
16th Jun, 2004 at 10:39:06pm
The best option ist to take out the drive and change one or two teeth, second option is to rotate the dizzy about 90 ?counterclockwise and change the sparkplug cables,
16th Jun, 2004 at 10:39:09pm
and will the timing being retuarded make the engine get hot |
16th Jun, 2004 at 10:41:09pm
i think i will turn the dizzy round |
17th Jun, 2004 at 08:05:27am
It will certainly run badly and be very slow!
AlexF |
17th Jun, 2004 at 06:20:37pm
screw a long bolt into the drive (it has a thread in the centre of it) and then be carefull and you shouldnt drop it in the gearbox no longer a series, but still 1.3 turbo.
![]() 2641 Posts Member #: 19 Post Whore newcastle |
17th Jun, 2004 at 09:19:40pm
eh , drop what into the gearbox Everyone knows that instructions only have to be read if the thing doesn't work....
18th Jun, 2004 at 09:11:58am
The dizzy drive...
18th Jun, 2004 at 10:42:28am
Can that happen?!?!
AlexF |
18th Jun, 2004 at 11:46:44am
i always use the bolt method, seems to work. Never dropped one in yet, hope i never do. Better to be safe than sorry though i guess. |
18th Jun, 2004 at 12:56:42pm
didn`t think the dizzy drive could drop into the box ??? Everyone knows that instructions only have to be read if the thing doesn't work....
18th Jun, 2004 at 07:08:10pm
it can :( .. never happened to me tho as i use the bolt method :) the suggested bolt is uber-good as it usualy has a tapered end, so is very easy to locate. turbo 16v k-series 11.9@118.9 :)
![]() 265 Posts Member #: 68 Senior Member Coventry |
18th Jun, 2004 at 08:07:39pm
i think this was more of a problem on old A-series engines, not A+ Sooperdooperturbocooperexpertengineering! |
18th Jun, 2004 at 08:27:21pm
really?? wel if anything the bolt makes the drive MUCH easier to put back in! turbo 16v k-series 11.9@118.9 :)
