| Home > Beginners Tech > first time turbo'er, 998 on T2 | |||||||
172 Posts Member #: 1600 Advanced Member Portsmouth, Hampshire |
21st Sep, 2007 at 01:41:15pm
after reading Will h post on turboing a 998 using a T2 and mirage manifolds, i have decided to do the build, i am also making a supercharger kit (very slowely)
21st Sep, 2007 at 01:54:24pm
standard 295 have just over 28.cc chambers (28.3cc?)
21st Sep, 2007 at 02:01:14pm
It's not so hard to measure the chambers. I think that someone on here knows the standard height of the heads. If your's is the standard height then you can assume it has standard chambers.
21st Sep, 2007 at 02:09:33pm
The head should be 2.75" or 69.85mm thick if it hasn't been skimmed. Then you should have approx 28.3cc chambers.
