Home > Help Needed / General Tech Chat > 2'' downpipe ?
minisinpa
Member #: 304
Hi-question to all:
Using a 2" downpipe with potjoint universals-looks like a tight fit.What's the best way to make the clearance?seems like a tight fit to me-any suggestions?Any body else use this set-up?How did you make the clearance?This is for a MK 1 subframe.......
Thanks-Garry
Edited by AlexF2003 on 17th Jun, 2004.
It is very tight yes but most people get them to fit with out moding them, mine went straight in.
sauber 200
Member #: 245
just fitted one on my sons car,no probs plenty of clearance,
fireman-sam
Member #: 301
bend the braket that holds it at the bottom a bit and it will fit fine if its the mini one but if it the metro one you will need to put a dent in the floor where it hits
Gibbo
Member #: 34
My Maniflow down pipe fits my MK2 no problem.
Tight yes, but fits.
Edited by Gibbo on 17th Jun, 2004.
Sometimes the 'ball' touches the underside of the tunnel, giving problems...
In this case, I identify where more clearaqnce is needed in the tunnel, and with an appropriate short length of 2x2, jack up the car at the tunnel in the offending area. It doesn't need much, and certainly you don't need to get the wheels clear of the ground, but it gives up to 20mm extra clearance in that local area!
minisinpa
Member #: 304
its not the ball the clearance between the potjoint and subframe should i have moved the motor forward? thanks garry
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
no one usualy has problems there!
alex
AlexF
just been out to look at mine and theres loads of room
got any pics ?
