| Home > Help Needed / General Tech Chat > megajolt (vacum tubes) | |||||||
25th Sep, 2007 at 11:43:56am
I have a 45 webber. i am now looking at put vacum pipes into the mainfold. Can anyone advise what size the holes and pipes should be. Has anyone got any pics with this done.
25th Sep, 2007 at 12:15:24pm
ah,
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
25th Sep, 2007 at 12:24:53pm
25th Sep, 2007 at 12:30:44pm
4 or 5mm would both do the job fine, get your unions to screw into the manifold first then get pipe to suit.
25th Sep, 2007 at 12:44:17pm
On 25th of Sep, 2007 at 12:15pm mini13 said:
ah, when you said vacum tubes i was expecting somthing like this ![]() nice thinking, though i think a little big for what i need |
25th Sep, 2007 at 12:46:26pm
On 25th of Sep, 2007 at 12:30pm Tom Fenton said:
4 or 5mm would both do the job fine, get your unions to screw into the manifold first then get pipe to suit. Although if it is for MJ then a TPS would be better on a Weber for NA use. Thanks Tom, i am taling about TPS but what do you mean by NA use? |
25th Sep, 2007 at 12:48:52pm
NA = Normally Aspirated e.g. no turbo.
25th Sep, 2007 at 12:51:00pm
every day i learn something new |
25th Sep, 2007 at 01:07:16pm
Philc, If you put in tubes with a 3mm bore into each leg of the manifold and pipe these to a T piece followed by a Mig 0.6 nozzle stuffed into the pipe and then lead it through an in line fuel filter.
25th Sep, 2007 at 01:30:07pm
any idea were i can get such tube |
25th Sep, 2007 at 01:51:23pm
Merlin Motorsport, Demon Tweeks, ebay, etc etc etc etc etc............
25th Sep, 2007 at 08:14:15pm
thanks guy's, i will get there eventually |
