| Home > General Chat > Firing Problem | |||||||
74 Posts Member #: 72 Advanced Member |
17th Jun, 2004 at 10:21:19pm
I have a problem with my cranky old mini, it just seems to stop firing on whatever cylinder it wants when it wants. |
17th Jun, 2004 at 10:22:04pm
its probably not the leads or the plugs then!
AlexF |
17th Jun, 2004 at 10:31:46pm
What else could it be? Everytime the leads are changed it goes like it should for a little while then its naffed again within a week :( |
18th Jun, 2004 at 07:49:17am
rotor, cap? |
18th Jun, 2004 at 08:52:53am
Ignition module...
Edited by Jimster on 18th Jun, 2004. On 17th Nov, 2014 Tom Fenton said:
19th Jun, 2004 at 04:44:33pm
Right I changed all the plugs, the HT leads, the rotor cap, the dizzy, the ignition module and it still does the same thing.
19th Jun, 2004 at 05:49:08pm
are you running too rich or lean which is shagging up the plugs really quickly?? On 15th May, 2009 TurboDave said:
19th Jun, 2004 at 07:41:52pm
Normal light brown coloured, but cylinder 4 wont fire although it is sparking (i shorted the plug out on the engine and it does spark)
20th Jun, 2004 at 09:15:07am
Just because it fires out of the engine doesnt mean it fires in the engine. Its a different ball game under pressure.
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
20th Jun, 2004 at 09:20:13am
You may have a cracked ignition coil, your problem sounds very familar to me.
20th Jun, 2004 at 12:04:24pm
I've changed everything already.
20th Jun, 2004 at 12:06:31pm
hmm, it maye be worth doing a compression test, see if no. 4 is the same as the rest. Has this just been put together, or was it running fine? On 15th May, 2009 TurboDave said:
20th Jun, 2004 at 12:22:29pm
its done around 5000 miles since rebuild, admitably its been thrashed but surely it shouldn't die yet.
Edited by MajicMini on 20th Jun, 2004. |
20th Jun, 2004 at 12:24:55pm
Have the rocker off and just make sure that the valves are moving ok too. worth a quick look, something sounds amiss |
![]() 341 Posts Member #: 259 Member grays, essex |
20th Jun, 2004 at 01:51:05pm
my 1.0 had the same problem, i changed everythin, plugs, leads,coil,dizzy and im sorry majicmini but i never did find the problem so i changed the engine!!! sory to put a downer on the situation!!! it may b small but it purfectly formed
