Home > Help Needed / General Tech Chat > Quick daft question...
jamesfawcett
Member #: 218
Bingley, West Yorkshire
The hub nut, which do you turn it, anti-clockwise or clockwise to undo it? Ive fucked up my cv joint trying to separate the driveshaft from it, and i hit it in the wrong place and broke the cage.
evolotion
Member #: 83
Glasgow, Scotland
anticlockwise on both of them, jsut like any other bolt :)
Denis O'Brien.
jamesfawcett
Member #: 218
ok :)
just been struggling tonite, 5 hours solid of trying to fit my new hubs. Collected them from leeds tonite wiht the new heavy duty ball joints and wheel bearings. Completely cocked up, i didnt put a cv boot on one, the next time i didnt have a c clip on one, then i didnt have it lined up right. All in all its been a completely messed up night, everythings gone wrong. Now ive chipped my cv joint trying to break it off the driveshaft, luckily i have another though so ive built that up with a new c clip etc, and now cant get the damn hub nut off! Its not even tightened the guy told me, but i must be doing something wrong! Im going to try get the right sized socket tomorow, ive been using an adjustable spanner like i always do, but this one is ultra tight, thats why i just asked lol!
VERY STRESSED!
Nick
Member #: 154
Midlands
had to change one of mine at the weekend cos the bearing had welded itself onto the CV, just held it striaght and gave it one clout with the lump hammer and it popped off, then just had to hammer the CV outta the hub. you'll need a 1" 5/16 socket for the hub nut and it needs cranking up to 150ft/lbs or until the car starts rolling with the handbrake on. its only one of the rear stub axles thats got a reverse thread dude.
the hub nuts can be tight, take the split pin out and just keep trying. I use an air gun and never have any problems
It's just the passenger side rear hub bearing that has a left hand thread...
jamesfawcett
Member #: 218
ok thats great! ok thanks, ive been using a bended round spanner, doesnt slip off but just wont budge. Going to buy the right sized socket in town today and use it with an extension bar.
b12
Member #: 247
Kent/Surrey Borders
feebs
I tried to get mine off with a socket and massive breaker bar
I was moving the car up hill with the handbrake on and the nut was still not letting go !!
The only way I could do it was by whacking the breaker bar with a hammer
I think they need to be shocked into releaseing sometimes
I think I will buy a impact driver as that would have no problems at all !
S
TurboLessTosser
air tools have their uses!!
b12
Member #: 247
Kent/Surrey Borders
I dream of having a nibbler !!
TurboLessTosser
Ooo er doenst that hurt *wink* lol!
yeah a nibbler has its advantages, havent got one but work has..
prefer an air saw and angle grinder myself!!!!
sauber 200
Member #: 245
feebs use a torque wrench no probs
nutter driver
Member #: 47
Not very sunny swanage
dont ever use a torque wrench to undo stuff. well, i suppose you could but it would be nfg for doing stuff up ever again....
evolotion
Member #: 83
Glasgow, Scotland
shock treatment(breaker bar + hammer), or take the complete assembly down to your local garage and give the guy a fiver to pop the windy gun on it :)
dont use a torque wrench !
Denis O'Brien.
if your near me you can use my windy gun no worries. *smiley*
jamesfawcett
Member #: 218
Got it off, took it to my friends house. With the extension bar it lifted the front of the car! we had a scaffolding bar over the end of it for more torque!
We ended up chizzeling it down and breaking it in two, it was air gunned up. Nothing would break it off. I put a new CV joint in, and new driveshaft and now the car is rolling again! Back on track!
Jobs left are...
Wire up headlights.
Put exhaust on (dreading that)
Find the nut for one of the trackrod ends
Get intercooler pipes! Got some 51mm radiator pipes from the scrappers which will work, but will they be suitable temporarily will they handle the pressure?
I undid the cap on the brake fluid topup thing, and squashed the pads in the calipers and bolted the calipers on, when i pumped the brakes up to test them, they have stuck on quite a bit and not released, the pedal travels the right ammount, but shouldnt the car roll? Do i need to do something else?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
lol
just use heat chaps... and they virtually fall off!
alex
AlexF
jamesfawcett
Member #: 218
lol might have to trythat next time!
Worse thing was the ball joints, threaded both top ones and they were brand new heavy duty ones.
Put them in a vice tonite nad precicly sawed (is that a word?) off the top few threads. worked fine! they were a right mess! Never want to do a ball joint ever again, paying a garage next time!
