Home > Technical Chat > Supercharger Questions ?????
mknight702
Member #: 1967
I hope these questions are new, I have searched but without success.
Q1) All of the aftermarket supercharger kits I have seen have a new alloy bottom pulley. Now ignoring the fact that I am not convinced about alloy pulleys, none of them have harmonic dampers. From the searches I did all seem to agree a harmonic damper is required, so how does this work???
By the way for my conversion I have sourced an MPI poly vee pulley and was planning some sort of serpentine belt to drive everything but this is a pain and if a harmonic damper is not required then I will make up a pulley to suit.
Q2) What sort of boost / drive ratio combinations are people getting? Every book / web site seems to give a different formula for calculating boost vs drive ratio and for my target of 10psi I am getting anything from 1.4 to 1.9 and all points in between. So I thought I would get some real world examples and verify some of the formulas.
Have fun,
Matthew
danboy
Member #: 1381
Have a look on here, it will give you some idea of where you need to be.
http://www.rbracing-rsr.com/turbosupermaps.html
Regards
Dave
This calculator seems to give the right sort of answers:
You can select the Eaton M45
mini23
Member #: 1296
Milford Haven Pembrokeshire
Here's a picture of mine striped down.
I think the pulleys are ford ohc one's which give the charger a 2:1 ratio and produce just under 10 psi @ 7k engine speed
mini23
Member #: 1296
Picture never got added! selected add attachments and selected it.
mini23
Member #: 1296
http://www.turbominis.co.uk/index.php?p=20&id=3448
Link to my pics
mknight702
Member #: 1967
Thanks Mini23
This confirms my thoughts, the Sprintex calculator for the Eaton M45 gives a drive ratio of 1.53 for a boost pressure of 10psi. If you actually have 10psi of boost at 2:1 then it brings into question the accuracy of the Sprintex calculator.
Out of interest the Sprintex calc gives a HP rating of about 140 how does that compare real world?
Who gets 10psi at 2:1 ?
140 hp is about right for 10psi boost and a good intercooler.
mknight702
Member #: 1967
mknight702
Member #: 1967
PS Nobody has answered the forst question about harmonic dampers?
neilj1678
Member #: 1297
Sunny Stockport
I would always use a damper. You could use the MPi pulley as you say or maybe you could fit an S type damper ring onto the alloy pulley you have in the kit?
http://www.minispares.com/Product.aspx?pid=36125
Regards
Neil
danboy
Member #: 1381
I think the figures from the Sprintex Calculator tie in pretty well with the graphs for the M45 in the link I provided above.
The 2:1 ratio at 7,000 rpm is taking the M45 right to the top of it's operating limit and is not to be reccomended in terms of best efficiency.
ie 25 HP to drive it and outlet temps very high.
If you feed sensible figures into the Sprintex spreadsheet and then transfer the figures to the eaton graphs it should give you a feel for what is happening.
Regarding the crank damper, my views on the subject are as follows:-
The damper was designed for a standard engine used in the normal Rpm range and as soom as anything is changed ie lighter flywheel , the damper will not be at it's optimum. I would not know where to begin to calculate what modifications to do to the damper to make it operate at the required rpm after the engine has been modified.
Some 998 & 1100 engines run with just a pulley and seem to last very well.
I do know a few people who have run 1275's without a damper and no problems followed.
Why can't you run with a damper and fit the pulley in front of the damper, it shouldn't be too difficult.
Regards
Dave
mini23
Member #: 1296
Here's my rolling road report
http://www.turbominis.co.uk/index.php?p=20&id=4084
Thigre
Member #: 1964
France
Beware of the Sprintex calculator as it give 0.65L per rev for the M45. Eaton themselves give 0.75L per rev.
Thierry
Mini British Open II 1275 SPI Full Stock
working on SSpi project
danboy
Member #: 1381
what is 45 cu in when converted to cc's
regards
dave
One litre equals 61.02cu ins.
So 45cu ins is 737cc
danboy
Member #: 1381
or 16.387cc x 45
well spotted Thigre
Regards
dave
Edited by danboy on 27th Sep, 2007.
Thigre
Member #: 1964
France
*wink* I will have a look to unlock the tab, so I can modify the value.
Thierry
danboy
Member #: 1381
Already tried but I can't do it.
Best of luck
Regards
Dave
Thigre
Member #: 1964
France
Ok, it's done...thanks to Google *tongue*
here is the unlock file with 0.75L/rev M45 blower.
Hope it help.
Thierry
EDIT: can't attach the xls file, but i can mail it (PM) or if someone can host it...
Edited by Thigre on 27th Sep, 2007.
Here it is...
http://www.davecoxon.co.uk/Blower_Calculator.xls
Edited by turbodave16v on 28th Sep, 2007.
