| Home > General Chat > o/t gearbox with no oil | |||||||
928 Posts Member #: 65 Post Whore South Yorkshire |
1st Oct, 2007 at 12:42:43pm
A friend at work had her merc a-class serviced 4 weeks ago, then the gearbox failed and the RAC said it sounded like there was no oil in it.
1st Oct, 2007 at 12:47:59pm
Someone im ashamed to know used to drive his 'scort around without any oil for quite a while, well so he says anyway!
1st Oct, 2007 at 04:01:16pm
I drove an old montego around for a while with no oil in the box- went fine for a week or so before it locked up on me - should have taken more notice of the oil trail! |
1st Oct, 2007 at 04:10:41pm
On 1st of Oct, 2007 at 12:42pm Neil8p said:
Is it possible for a gearbox to do 30 miles a day for 4 weeks with little or no oil in it? In my opinion, NO. I once heard a story of someone fitting a rebuilt box to a VAG hot hatch, these boxes have output flanges in the diff meaning that theoretically they can be left filled with oil, unlike Ford/Peugeot/Nissan etc boxes that dump their oil when you remove the shafts. The person who owned the car told the guy refitting the gearbox that the other guy who had rebuilt the gearbox had put oil in it. 6 miles after fitting the box whilst road testing it became evident this was not the case. In addition, more and more modern cars now have non-serviceable gearboxes, e.g. they are filled with oil and sealed supposedly "for life", I've certainly never known any garage do much with g/box oil as part of a service.
1st Oct, 2007 at 04:22:18pm
I've never changed the gearbox oil in my mini, how do I do it? On 15th May, 2009 TurboDave said:
1st Oct, 2007 at 04:35:18pm
We actually got that question on the Norwegian mini board a few weeks ago:) |
1st Oct, 2007 at 04:43:24pm
Its quite easy Jim. Theres a grease nipple on the drivers side of the gearbox, but make sure you disconnect the battery first. :) Edited by Jason G on 1st Oct, 2007. On 19th Jan, 2010 wil_h said:
1st Oct, 2007 at 04:57:17pm
I though that you separated the engine/box, tipped the oil out, filled it back up and re-assembled.
In the 13's at last!.. Just |
1st Oct, 2007 at 05:15:41pm
Damn it...never thought of doing that. Is there a special tool doing it that way??? Edited by Jason G on 1st Oct, 2007. On 19th Jan, 2010 wil_h said:
1st Oct, 2007 at 08:15:04pm
I did 6k miles in a Vaux Viva... the output seal was shot and so it lost nearly all the oil you put in within the 1st 5 miles!!
AlexF |
1st Oct, 2007 at 08:32:06pm
Had a fiat uno....lasted about 5 hours without oil. Typical Italian gearbox though! On 19th Jan, 2010 wil_h said:
1st Oct, 2007 at 08:44:45pm
werent the uno gearboxes also lubricated by the engine oil or am i thinking of the Pandar F.I.R.E. engine?? or am i thinking that it was the inner CV joints that were oil filled from the gearbox so when the split they drop the oil? Edited by Sprocket on 1st Oct, 2007. On 26th Oct, 2004 TurboDave16v said:
1st Oct, 2007 at 08:54:33pm
in my opinion neil its possible and sound about right
1st Oct, 2007 at 09:17:33pm
manual or automatic if its manual then inho it is possible, ive recently witnessed a yaris gearbox which covered an unbelievable 6000 miles with out gearbox oil in, maybe it was only used for short journeys.
1st Oct, 2007 at 11:07:38pm
if they havent invoiced you for gearbox oil, then id say you have a strong argument. "Turbo's make torque, and torque makes fun"
2nd Oct, 2007 at 09:06:18am
If you remove the gears I guess it would be quite obvious if it hasn't been run without oil? On 13th Jul, 2012 Ben H said:
2nd Oct, 2007 at 10:12:36am
Thanks for the advice.
2nd Oct, 2007 at 11:58:55am
Some years ago I heard a tale about an oil chane a guy had done on a Renault.
2nd Oct, 2007 at 01:21:15pm
On 1st of Oct, 2007 at 05:15pm milamber said:
Damn it...never thought of doing that. Is there a special tool doing it that way??? I think that you would have to be a 'special tool' to do it that way!! Edited by theoneeyedlizard on 2nd Oct, 2007. In the 13's at last!.. Just |
2nd Oct, 2007 at 02:10:20pm
On 2nd of Oct, 2007 at 11:58am danboy said:
Some years ago I heard a tale about an oil chane a guy had done on a Renault. The engine and gearbox drain plugs were very close together. He removed the gearbox plug thinking it was the sump plug, drained the oil, refitted the drain plug, then poured 5lts. of oil in the engine. Set off on a run and wondered why the engine smoked and the gearbox was noisey. Regards Dave That happened on a VW passat at my fathers petrol station too. They quy that worked for my father in the service garage did exactly that, and the owner of the car left happily, and then came back a day later with the car with a broken box, and engine. He claimed his money back:) VW paid the rest:) |
784 Posts Member #: 912 Post Whore North Yorkshire |
2nd Oct, 2007 at 09:23:30pm
My friend and I went to collect his dad's AMG Merc thing V8 superchargered job.
I drill holes in everything..! |
2nd Oct, 2007 at 10:06:36pm
On 2nd of Oct, 2007 at 09:23pm Si P said:
My friend and I went to collect his dad's AMG Merc thing V8 superchargered job. On the way home it got a proper test drive if you know what I mean.
We caught up with a gt3 porsche on the way back so you can guess what happen next. Doing Big Mph's overtaking on the wrong side of the road the Merc decided to drop out of gear and I mean no gear at all. Well the porsche near went into the boot and we nearly had a head on to. Bloody scary...! Plus £200.000 quid’s worth of cars nearly totalled. Anyway we survived and so did the porsche guy. The Merc at this point although in one piece still would not drive. So a phone call to Merc and out they came to collect the car. Once back at the dealers and after further inspection they found that in the service they just done on the car and charged for. That some how they had not filled the gear box up to the adequate level with oil.! Resulting in the Merc computer deciding game over, and no more fun today. If only it could see it might have changed its mind. So Merc think oil is important although they sometimes forget to put it in Si to make matters worse, those thigns dont even have a dip stick, jsut a cap over the dip stick tube. checking the oil level is a dealer only activity! turbo 16v k-series 11.9@118.9 :)
