| Home > Help Needed / General Tech Chat > Tracking Setup | |||||||
567 Posts Member #: 102 Post Whore Pennsylvania USA |
2nd Oct, 2007 at 10:47:35pm
I have had the steering rack off and would like to set the tracking myself. What is the best way to get this done?
2nd Oct, 2007 at 10:50:11pm
Tracking gages , or pice of string from back wheels?
Edited by cossierick on 2nd Oct, 2007. |
3rd Oct, 2007 at 10:15:04am
Carefully measure from inner wheel rims under the car is the nearest way to get it somewhere like without access to tracking gauges.
3rd Oct, 2007 at 12:38:39pm
Find something to mark out 4 corners (cones work well).
82 Posts Member #: 939 Advanced Member |
3rd Oct, 2007 at 01:24:25pm
thats exactly how i have done my tracking |
3rd Oct, 2007 at 01:52:53pm
dont forget to centralise the rack first. there should be a rubber bung were the column goes on left hand drive cars. remove the bung, undo the can and put something in the hole. turn the wheel and you will know when its right. |
3rd Oct, 2007 at 03:25:34pm
Thanks for the help guys. |
3rd Oct, 2007 at 03:28:50pm
string between front and rear wheel is difficult to use on a mini as the front and rear track width is not the same. |
3rd Oct, 2007 at 04:16:10pm
Yeah I found that out there is like 7cm difference between the front and rear. |
3rd Oct, 2007 at 04:20:48pm
3rd Oct, 2007 at 05:28:47pm
thats not right, its more like 2 cm if I remember correctly. (I may not) |
3rd Oct, 2007 at 06:06:48pm
i bet it varies depending on which drums your using at the back. "Turbo's make torque, and torque makes fun"
3rd Oct, 2007 at 06:17:19pm
yes, but around what I said. I tried to remember the value on my car. And it will also depend on the type of front brakes of coure. like vented/non vented Edited by miniminor63 on 3rd Oct, 2007. |
3rd Oct, 2007 at 06:31:37pm
It has vented disks on the front |
3rd Oct, 2007 at 07:20:11pm
On 3rd of Oct, 2007 at 03:28pm miniminor63 said:
string between front and rear wheel is difficult to use on a mini as the front and rear track width is not the same. It doesn't matter (so long as it's not so far away your measuring device can't reach). I usually set the string about an inch or so from the closest obstructing part. The strings don't have to be parallel either (obviously you need to know how far your markers are appart fore-aft and diagonal) as the trig will take all that out. What you should end up with on your drawing are Outline Fore-aft separation of markers each side Diagonal separation of markers This will give you a parallelagram (unless you spend ages arranging the markers into a perfect square or rectangle) Detail You should then have the distance between each side of each wheel and the relavent string. You should now be able to reduce it all down to triangles (for example take the shortest distance between wheel and string on each wheel from the longest and you will be effectively left with a simple triangle). Once you have worked out all your triangles (as I said, makes it eaiser if you draw it all on a single sheet of paper) you should be able to work out the relationship between each wheel on the same axle. Job done. Did that make sense????? I will try to put it all into a spread sheet when I get chance and post it up. Every day is a school day ...........
3rd Oct, 2007 at 08:10:17pm
my post where pointed toward cossiericks reply Roger. I get your point. The way I do mine is:
100 Posts Member #: 745 Advanced Member Northampton |
4th Oct, 2007 at 12:35:43am
depending on the state of the individual car: the string thing where you aim to get the rear wheels in line with the front can (and does) lead to one of the rear wheels toe-ing out whilst the other is toe-ing in. (whilst the total rear toe may still well be toe-in).
Edited by icklemini on 4th Oct, 2007. |
4th Oct, 2007 at 07:20:56am
Good point dave. I forgot to state you need to know the distance from the string to the centre of each wheel so you can tie all the triangles together. Every day is a school day ...........
