| Home > Technical Chat > An idea I had......... | |||||||
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
5th Oct, 2007 at 03:00:23pm
I was having a chat to my engineer mate about dropping compression ratios. I'm actually a big fan of the decompression plate idea, I think if you match the bores of the plate to the piston bowls, you retain squish. That's a good thing.......
Bugger off, I'm getting there. |
3596 Posts Member #: 655 Post Whore Northern Ireland |
5th Oct, 2007 at 08:37:45pm
A better picture might help, because I havent a clue what you are describing lol. 9.85 @ 145mph
5th Oct, 2007 at 10:36:22pm
I'll have some of what you are on! Hegemonkey.
5th Oct, 2007 at 10:47:35pm
decomp plates are shite IME AlexF |
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
5th Oct, 2007 at 11:41:27pm
I agree with alex, 1 of 2 gaskets to blow. Back once again like a renegade master |
6th Oct, 2007 at 01:15:58am
in the first bit where you refer to using the decompression plate to basically build out the chamber shape rather than extra boree height, i think this would be disasterous as there would be un sandwiched material would would probablt melt and shag your engine "Turbo's make torque, and torque makes fun"
6th Oct, 2007 at 06:39:04am
I fail to see the point. Within reason any compression ratio you may want to use is achieveable with parts/methods already available.
6th Oct, 2007 at 07:24:57am
I have to agree with Tom. With modern engine management just around the corner for the A series and good ignition control already here people should be looking at higher CRs.
6th Oct, 2007 at 04:10:49pm
It all sound like a lot of fing around to end up with an engine with a lot of non standard parts to cause issues later on....
Edited by Joe C on 6th Oct, 2007. On 28th Aug, 2011 Kean said:
6th Oct, 2007 at 08:56:50pm
As folks say above....with the cost of machining, decent pistons with required dish and a good head would be far less. Reliablility with the proven knowledge around would be far better.
On 19th Jan, 2010 wil_h said:
Got the bits, just can't find the motivation to put it together again.
