| Home > Help Needed / General Tech Chat > Rear wheel bearings | |||||||
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
17th Oct, 2007 at 04:46:14pm
Hi can anyone tell me the torque settings for the rear nuts holding the hubs on, the bearings are the later taper bearings. I have looked in the haynes manual but to no avail. Many thanks chirs. |
17th Oct, 2007 at 04:59:16pm
finger tight? |
17th Oct, 2007 at 05:32:22pm
Rear wheel bearing I normally jack the car up & tighten till theres no play in the wheel. Don't over tighten though, and make sure they don't bind up. Normally a gnats more than finger tight. On 19th Jan, 2010 wil_h said:
17th Oct, 2007 at 05:36:55pm
Taper roller bearings can be torqued up FT, this is because there is a metal sleeve in the centre meaning no matter how tight you do the nut, there is no more axial load placed on the rolling elements in the bearing.
22nd Aug, 2008 at 05:05:57pm
I am excavating this so its more likely to be found by searchers,
Edited by Joe C on 22nd Aug, 2008. On 28th Aug, 2011 Kean said:
22nd Aug, 2008 at 07:47:19pm
Things must have changed a lot since I replaced wheel bearings on anything.I have bnever seen taper rollers with a sleeve -always tighten to seat the bearing and slack off till barely perceptible play.You can put several tons axial pressure on a taper roller and it will still spin freely, but it wont last long.Ball bearings in a wheel bearing scene are usually radial contact,must be assembled the right way round, and on to a sleeve that prevents axial loading.Maybe Minis are completely different now, but I have my doubts. |
13th May, 2009 at 07:01:11pm
On 17th Oct, 2007 Tom Fenton said:
Taper roller bearings can be torqued up FT Is FT finger tight or fucking tight? Also what are peoples preferences on rear wheel bearings genuine, Timkin or does make any real difference. Isambard Kingdom Brunel said:
![]() 1014 Posts Member #: 238 Post Whore essex |
13th May, 2009 at 07:13:30pm
i've always done them at 60lbf as it says in the haynes. ““A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”” - Jeremy Clarkson
13th May, 2009 at 07:45:34pm
I've always taken FT as Fully Tight On 11th Feb, 2015 robert said:
14th May, 2009 at 12:47:25am
http://www.timken.com/EN-US/solutions/auto...ngs_English.pdf
Edited by Sprocket on 14th May, 2009. On 26th Oct, 2004 TurboDave16v said:
