| Home > Help Needed / General Tech Chat > how easy | |||||||
45 Posts Member #: 2014 Member Carlisle |
21st Oct, 2007 at 11:52:06am
is it to put an oil feed into a normal a series block? for turbo purposes? |
21st Oct, 2007 at 11:56:49am
hi and welcome! easy, the turbo gets its oil feed from the oil pressure switch hole on a t piece type setup. get a braided oil feed pipe rather than the standard hard pipe. makes turbo removal easyer. the oil return goes into the manual fuel pump hole. no longer a series, but still 1.3 turbo.
21st Oct, 2007 at 12:06:50pm
so im guessing something along the lines off
21st Oct, 2007 at 12:19:19pm
yep thats the one. no longer a series, but still 1.3 turbo.
21st Oct, 2007 at 12:21:06pm
cheers for the help!! |
21st Oct, 2007 at 03:33:28pm
What about the return? In the 13's at last!.. Just |
21st Oct, 2007 at 03:37:55pm
goes into the hole left when you would have removed the mechanical fuel pump turbo 16v k-series 11.9@118.9 :)
21st Oct, 2007 at 03:39:42pm
Just checking! In the 13's at last!.. Just |
