| Home > Technical Chat > Best buy for cheaper turbo | |||||||
![]() 87 Posts Member #: 2018 Advanced Member Witton Park, Northeast |
24th Oct, 2007 at 04:20:10pm
What is the best turbo to go for to put onto my modified 1275 block (when it's done!) bearing in mind I don't want to pay loads and don't mind it being second hand to overhaul if necessary. I have never dealt with a turbo'd mini before and I need all the information for when the time comes for the build to start. I know I'll have to cut away part of the bulkhead but I need to know my best options for which turbo to go for and where to get one! Also I've read a lot about mirage manifolds, whats the deal with these and whats the best to go for?
24th Oct, 2007 at 05:01:46pm
In the 13's at last!.. Just |
24th Oct, 2007 at 05:53:43pm
Thanks that helps a lot ..... by the way I've sent you a couple of questions on ebay! :) Is it your engine? |
24th Oct, 2007 at 06:12:10pm
Engine?? In the 13's at last!.. Just |
24th Oct, 2007 at 06:14:04pm
This would be a good option if you wanted to keep the cost down. £120 and it includes the carb.
24th Oct, 2007 at 06:18:33pm
That seems a good option .... but thats not an engine is it ... it's just the torbo set up? What I was referring to earlier was this
Edited by DemonPixie on 24th Oct, 2007. |
24th Oct, 2007 at 06:25:54pm
That engine is not mine, I was just making people aware of it as it's going cheap.
24th Oct, 2007 at 06:28:25pm
Ok thanks. Well I sent whoever it is a message lol! :) |
24th Oct, 2007 at 08:17:50pm
That turbo set up you showed me .... would that go straight onto the block with the parts that come with it? And what modifications will I need to make to the block to accommodate it?
24th Oct, 2007 at 08:33:53pm
On 24th of Oct, 2007 at 05:01pm theoneeyedlizard said:
Cheapest option is the T3 off the metro turbo as they, and more importantly the manifolds are available second hand (look on ebay). You should be able to get the whole setup for about £150. The rebuild kit is around £50. For this option you will need to cut the bulkhead and fit a box. Speak to milamber, he does an extra large one that's perfect. The other option is to go for a mirage setup. This is a stainless manifold setup that costs around £350. You'll need to source a T2 / T25? (correct me if i'm wrong). Benefits are 1. less lag (depending on turbo choice) 2. no cutting of bulkhead. 3. water colling (again this depends on turbo choice) Have a look at Nic's car for an example of the Mirage setup. I hope this helps you decide. This is a T3 apparently .... will it fit a mini? http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=230183595528 Edited by DemonPixie on 24th Oct, 2007. |
24th Oct, 2007 at 09:00:34pm
Yep, it'll bolt right on up.
24th Oct, 2007 at 09:22:19pm
OK thanks |
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
24th Oct, 2007 at 10:29:38pm
i thought the rs turbos had a different stud pattern to the metro ones? |
25th Oct, 2007 at 08:36:13am
I think that TurboDave was referring to the link in my post
25th Oct, 2007 at 11:27:15am
oh cool sorry |
25th Oct, 2007 at 11:33:33am
No I think turbodave was talking about a turbo I linked to on ebay, because it isn't a mini/metro one.
25th Oct, 2007 at 01:17:50pm
One thing that is worth considering is that if you can't weld and your are having to pay for someone to weld your bulkhead box in, then it could be worth going mirage setup as it could work out to be around the same price. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th Oct, 2007 at 01:42:12pm
Ah you see I know a clever little man who can weld and do any machining for me and he'll do it for the price of a cuppa or such like lol! Edited by DemonPixie on 25th Oct, 2007. |
25th Oct, 2007 at 03:00:43pm
Well, in that case - you need to go the tried and VERY tested route, and purcvhase everything as it was/is fitted to a metro turbo.
25th Oct, 2007 at 05:32:59pm
Excellent :) |
