Home > Help Needed / General Tech Chat > ecu
sammyloo
Member #: 212
if i bin ecu what do i need to replace it with
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
like someone already said....
the metro ecu has NOTHING to do with the ignition...
All it does is alter the boost, so rip it out and run a bleed vlave!
alex
AlexF
sammyloo
Member #: 212
where would i fit the bleed valve
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
in the line between the plenum and the wastegate acatuator.
alex
AlexF
sammyloo
Member #: 212
my ecu is wired to the control valve solenod do i need it
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
nope!
Remove that as well... all the "control valve solenod" is act as an electronic bleed valve. So in effect you remove the ecu and its output, replacing it with a user adjustable device.
alex
AlexF
sammyloo
Member #: 212
thanks for your help i have one more question i have been told to put a lunenition ignition system on is this going to be better than my mg turbo dizzy this may sound stupid but what adjustable device thanks
Stick with the mg turbo ignition. does the job as well if not better than the lumention. *smiley*
sammyloo
Member #: 212
do you have any ideas on how the mg dizzy is wired up
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
yup...
2 wires... st8 onto the coil... one is positive and the other negative!
alex
AlexF
sammyloo
Member #: 212
thank for your help hopefully i can get my mini running now
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
*happy*
Not a probelm :)
alex
AlexF
b12
Member #: 247
Kent/Surrey Borders
BEWARE
"2 wires... st8 onto the coil... one is positive and the other negative! "
ONLY if not running a ballast resistor !!!
if you have a Ballast resistor
take the 12v from the fuse box to the dizzy rather than the coil + as you dont get a full 12v
Steve
Edited by b12 on 22nd Jun, 2004.
TurboLessTosser
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
The only coil you can run with this system is a 12v coil *wink*
But good point steve !!
alex
AlexF
jamesfawcett
Member #: 218
Bingley, West Yorkshire
erm. oh dear.
ive got the coil and dizzy my metro had in, and it has the resistor! never had problems starting though?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
change it...
bigger spark and the elec ign will work properly!
alex
AlexF
