| Home > Help Needed / General Tech Chat > Sourcing a cambelt? | |||||||
30th Oct, 2007 at 10:18:32pm
Ive been searching for a cambelt but have no idea what car to get it off. Im using Honda pulleys so ideally a stadard Honda belt would be just the ticket but as usual nothing is that easy as they don't do it in the right length (no. of teeth).
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
30th Oct, 2007 at 10:43:11pm
there should be some companys which make belts of your own spec, obvoiously would have to be measured up well and give them the best information you can David. |
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
30th Oct, 2007 at 11:06:51pm
I went into my local motor factors and they had a book with all the different profiles of belt and teeth, then the number of teeth. I worked mine out from the pitch of the teeth then the number of teeth i needed! Mine has toyota pulleys and i have an alfa romeo 1.7 146 cam belt for mine. Think its a QD book that had it in. |
30th Oct, 2007 at 11:13:47pm
Yeah ive had a look for a custom belt supplier but can't find any that do automotive? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
30th Oct, 2007 at 11:18:02pm
On 30th of Oct, 2007 at 11:06pm antman said:
I went into my local motor factors and they had a book with all the different profiles of belt and teeth, then the number of teeth. I worked mine out from the pitch of the teeth then the number of teeth i needed! Mine has toyota pulleys and i have an alfa romeo 1.7 146 cam belt for mine. Think its a QD book that had it in. I know the pitch and no. of teeth and I even managed to get a copy of one of the books that list all makes and models but it doesn't say what profile the belt is e.g. square, round or pitch. The odd thing is that the belt is a 3/8s pitch but the profile is HTD and these are only available inpitches 6mm 8mm etc. Its seems that automotive belts are a mix of the 2 industrial belts. lol Just out of interest have your pulleys got the same profile tooth as this?
Edited by matty on 30th Oct, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
30th Oct, 2007 at 11:37:35pm
aah, at work a department fit air conditioning to bus's
David. |
31st Oct, 2007 at 12:28:07am
Profile is HTDA9.525 and is specific to automotive use. where as HTD 6, 8, 10 and so on is a common drive line available almost anywhere in any lenght
Edited by Sprocket on 31st Oct, 2007. On 26th Oct, 2004 TurboDave16v said:
31st Oct, 2007 at 08:02:28am
Thats the way i worked mine out basically, think there are about 10 different profiles for car use in the book. I looked at the whole internet research thing and buying belts but found it so easy just bugging my local motor factors. |
31st Oct, 2007 at 11:29:41am
On 31st of Oct, 2007 at 12:28am Mini Sprocket said:
Profile is HTDA9.525 and is specific to automotive use. where as HTD 6, 8, 10 and so on is a common drive line available almost anywhere in any lenght That means the pitch is 9.525 Run some masking tape around the pullies, cut and measure it. Divide this by 9.525 and this will give you the number of teeth. you then have to find a belt with that number of teeth and the width you want. Ford Zetecs, Hondas, Rover, Mitsubishi, subaru, are a few who use this profile. IIRC the number of teeth will vary depending on the route of the belt, between 121 and 131 teeh?? Ah cheers sprocket, I had a feeling that later Ford and Rover were the same. Ive already cut an old belt to length so thats no problem, i'll probably try your method just to double check as I recon i could get away with a few teeth more or less if need be. The search continues..lol
1st Nov, 2007 at 11:17:53am
1st Nov, 2007 at 01:08:07pm
Which DCI engine is it from as they seem be range from 132 teeth to 153? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1st Nov, 2007 at 02:02:47pm
I've got it written down at home, I think 1.9 diesel scenic, but I'll check for you,. On 15th May, 2009 TurboDave said:
5th Nov, 2007 at 01:57:26pm
Still had no luck! The length needs to be as close to 1143mm as possible (120 teeth), can't seen to find anything that is the right width, tooth profile and length?
