| Home > Help Needed / General Tech Chat > Themostats wondering? | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
31st Oct, 2007 at 11:11:01pm
Wonder what themostat i should have in my 1293 turbo mini sport sold me a 70 degree one is this right? Engine seems to be running hot and acording to my water temp gauge its a near on a 100 which i don't believe but i dont really no any help cheers |
1st Nov, 2007 at 12:54:05am
unleaded should run the 88 On 26th Oct, 2004 TurboDave16v said:
1st Nov, 2007 at 01:18:36am
im on a 74 with a few holes |
13th Nov, 2007 at 11:59:46pm
so will i do any damage running a 70?? |
14th Nov, 2007 at 01:03:38am
74 deg stats are the right temp for power!
14th Nov, 2007 at 08:31:17am
i run a 74 with no problems, few holes as has been mentioned.
14th Nov, 2007 at 09:21:51am
what temp should it be running sud still? cheers oh and how many holes five Edited by Zeemax Power on 14th Nov, 2007. |
14th Nov, 2007 at 11:40:49am
Am i reading that right Steve, you said a 74 kills the engine but recommend fitting one or am i being blonde? |
14th Nov, 2007 at 11:26:32pm
If you are having overheating problems and the stat is working correctly, then it wont matter what temp stat you put in it will still overheat.
14th Nov, 2007 at 11:44:48pm
seem to just about when stood but drops when drive oh and if i put my other fan on comes down to. What temp should it be running about? |
14th Nov, 2007 at 11:50:00pm
thats normal then
15th Nov, 2007 at 10:12:50pm
i'm not sure now the thermostat i thought was 70 but temp say a hundred hows that work confused now. And how many holes we talking benross? |
15th Nov, 2007 at 10:54:59pm
The thermostat controls the temperature of the engine only if the cooling system has the capebility to reject it. if it cannot get rid of the heat the temperature will rocket out of control even when the thermostat is working correctly.
17th Nov, 2007 at 11:26:26am
wat u reckon first port of call? |
