| Home > Technical Chat > T25 on Mirage manifolds? | |||||||
![]() 143 Posts Member #: 1506 Advanced Member Cheshire |
2nd Nov, 2007 at 11:25:03am
I know that some of you guys use them but...
Check out the (slow) progress at.......
2nd Nov, 2007 at 01:32:07pm
1. Yes It will fit
2nd Nov, 2007 at 04:13:37pm
same as me, i also gorund some of the exhaust casting on the turbo but nothing major and it was all done with an angle grinder.
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
2nd Nov, 2007 at 07:42:13pm
t25 from a rover 220 tomcat is what you need, although you will need to get hold of another compressor housing with the correct a/r since the rover unit has an integral dump valve built -in that gets in the way on the back of the block
3rd Nov, 2007 at 09:35:07am
Thanks guys Check out the (slow) progress at.......
3rd Nov, 2007 at 01:54:33pm
Now that you mention the Tomcat turbo, you can get a blank-off plate to replace the built in dump valve. Will this alleviate the clearance issues or would a new housing still be the best way? On 7th Nov, 2008 Nic said:
3rd Nov, 2007 at 04:24:49pm
nope, need to get rid of it as it gets right in the way.
