Home > Help Needed / General Tech Chat > N/A Question
Anton
Member #: 764
Staffordshire
Simple question really.. I run Morspeed 300deg Scatter Cam (also known as MED AGSP) in a 1293cc lump atm timed to 104deg.
I'm about to upgrade to a 1380cc lump do I need to adjust the cam timing to suit the 1380 compared to the 1293? The compression ratio will be the same or maybe slightly more.
I think not, but I thought it was worth asking before I build it this week.
Cheers Guys!
Alex1340
Member #: 111
Loughborough
i belive that should be fine to keep that cam. The cam timming i belive will need to be re-set but know idea what to. I would contact Simon at morspeed and ask him.
why? a scatter cam, is it in a full cooking race motor ?
i Personally dont like scatter cams
they are over rated
there a band aid to try and cure the 5 port robbing
a TRUSTY 649 or the modern equivalent STR 930 would produce more power and torque than this scatter cam
only my opinion
johnK
Member #: 690
Norfolk
Anton - your cam timing will be fine - I'm sure I used to run the 1380+agsp at 106/107 degs, not sure how simons cam compares to the AGSP in this respect though - have you asked him?
what valve sizes do you have in the head?
- nice to see you are going for more bananas - sure you don't want to sneak a K head on there while you are at it!!
JK
If Carling made Mini engines
Anton
Member #: 764
Staffordshire
cheers guys. I will have a quick natter with simon later then.
Engine is a daily driver. (into birmingham everyday) And has been for 12months. No problems with cammyness as its fitted with a megajolt.
head is 37mm inlet 31mm exhaust . I wish i could afford the k head conversion tho. One day one day :)
