| Home > Help Needed / General Tech Chat > fuel filters and pipery Need help asap! | |||||||
![]() 265 Posts Member #: 68 Senior Member Coventry |
24th Jun, 2004 at 08:48:34am
guys, Sooperdooperturbocooperexpertengineering! |
24th Jun, 2004 at 09:59:01am
most people run a filter between the tank and pump and between the regulator and carb, i personally use those little plastic see through filters although they probably aren't ideal. On 20th Oct, 2015 Tom Fenton said:
24th Jun, 2004 at 01:33:11pm
I cut the tabs off the taper on the plastic one to make the outlets 8mm Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
102 Posts Member #: 155 Advanced Member |
24th Jun, 2004 at 04:12:24pm
i would use a high flow filter to avoid loss of fuel pressure and would install it before the pump this would avoid any debris damaging the pump, you can get high flow filters at demon tweeks but the same brand is available at fuelsystem.co.uk for lots cheaper also they offer all diameters available, i've used em they are very good plus thers no charge for delivery ! |
24th Jun, 2004 at 11:46:54pm
i've used a pre turbo filter from mini speed, ?42 quid though, put it before the pump to stop it getting fucked, they really dont recomend the inline glass ones etc. |
