| Home > Help Needed / General Tech Chat > air to liquid intercooling | |||||||
18 Posts Member #: 303 Member |
24th Jun, 2004 at 02:26:22pm
Just out of interest, does anyone use air to liquid (to air) intercooling? Oh yeah anyone turboed a 16-valve head from KAD? Bet that'd be bloody quick! |
24th Jun, 2004 at 03:23:51pm
Its often called a charge cooler... you have two rads..
AlexF |
24th Jun, 2004 at 03:41:49pm
My Subaru uses a charge cooler. And that's got 200bhp and dosen't break gears. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 2641 Posts Member #: 19 Post Whore newcastle |
24th Jun, 2004 at 03:56:29pm
ok , keeping this mini turbo only...
![]() 164 Posts Member #: 206 Advanced Member Milton Keynes |
24th Jun, 2004 at 03:57:21pm
My subaru's dont 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
24th Jun, 2004 at 04:00:13pm
Your Subaru also doesn't have a KAD head does it Wil AlexF |
24th Jun, 2004 at 04:09:39pm
You still rely on exactly the same cooling medium;
24th Jun, 2004 at 04:13:15pm
ok , thought that 1/4 would suffer as the water would be heating up as you sit waiting to go and would rise above air temp and it would take a while to cool the charge..
24th Jun, 2004 at 04:19:46pm
Totally agree Dave... I'm talking about applications and circumstances really. The main difference is the time factor, drag racing last very little time, in fact you could say the less the better!!!! On track thou you dont want to have to pull off after 3 laps because your acts are sky high.
AlexF |
24th Jun, 2004 at 04:24:31pm
ok , so its not worth no to the hassle of fitting one then?? Everyone knows that instructions only have to be read if the thing doesn't work....
24th Jun, 2004 at 05:42:58pm
I've read about charge coolers in the book by Corky Bell called "Maximum Boost" and he says that with charge coolers you can use more boost because the density is increased and so some pressure is lost. On a further note, I would have thought that charge coolers would still would better on track racing (even though the water heats up quickly as a result of could heat conductivity) because you can install a radiator at the front that gets rid of most of the heat before passing back through the core of the charge cooler, and therefore the water would still be below ambient air temperature (allowing further cooling). Anyway I don't really know, any experts on the subject? |
24th Jun, 2004 at 10:50:07pm
why not install both, charnge and intercoolers?? or is that a silly question? |
24th Jun, 2004 at 10:58:22pm
like where Everyone knows that instructions only have to be read if the thing doesn't work....
24th Jun, 2004 at 11:13:52pm
I'm sure with some creative pipe work it can be done!
24th Jun, 2004 at 11:27:53pm
it's possible |
25th Jun, 2004 at 07:30:29am
My subaru has two 8-vale heads but I don't think KAD made them.
25th Jun, 2004 at 08:50:44am
On 25/06/2004 07:30:29 wil_h said:
(he's struggling to keep up with me) Hee Hee!!! That sounds like an interesting machine though! Space restriction has to be a winner for the charge cooler, but the pump, pipework and chargecooler itself might end up taking even more room!!!
They will only be as efficient as the frontal area of the water heat exchanger, as we all agree on! Using a diddy little oil cooler compared to something the size of a metro radiator for the cooler is an extreme example... On 17th Nov, 2014 Tom Fenton said:
25th Jun, 2004 at 09:05:40am
it's a very interesting machine. And for a normally aspirated 998 it's bloody fast (faster than any NA 998 mini). And its grip is immense. see below
25th Jun, 2004 at 09:51:38am
Now That's a quality car, and a great action snap! On 17th Nov, 2014 Tom Fenton said:
25th Jun, 2004 at 10:07:43am
LOVE the imp!
AlexF |
![]() 105 Posts Member #: 133 Advanced Member Jamaica |
25th Jun, 2004 at 04:38:17pm
a friend of mine uses a charge cooler BUT only for quarter mile runs.
'I swear to use the Boost, The whole Boost'
25th Jun, 2004 at 08:54:55pm
That's an what's called an ice-chest and is a one-shot charge cooler, and maybe the most effective in terms of heat transfer. However, some dragsters have liquid nitrogen sprayed on pipes to cool it.
26th Jun, 2004 at 07:45:30pm
You still want a cold air feed... don't make any cooling system work harder than it needs to!
AlexF |
27th Jun, 2004 at 10:31:46pm
Yes, of course |
28th Jun, 2004 at 01:15:47am
but on a light car like the mini, would the weight mpenalty of al this gubbins not out-weigh any advantage... turbo 16v k-series 11.9@118.9 :)
So non-mini but the theory should be exactly the same.
