Home > For Sale > T3 bits, N/A inlet manifolds & 22G270 Backplate.
Ok,
Having a bit of a clearout,
If any of the below are any use make me an offer, otherwise they're going on ebay.
T3 bits, various bolts & gaskets, .25 A/R exh housing, centre section with oil bolt (no oil line), oil drain and hose, compressor housing, and air pipe and hose.
An 1 3/4" inlet manifold (make unknown), pretty similar internally to the non turbo MG metro manifold i think. Has location ring grooves
Another 1 3/4" inlet manifold (make unknown), similar to an oselli torquemaster i think, smallish straightish runners, carb ends up quite low down. No location ring grooves.
A 22G270 Back plate, may have been machined thiner from the back for lightening?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
PM sent
