Home > Help Needed / General Tech Chat > Jap alternator and toother belt drives
has anyone done this?
there isnt enough thread to fit the toothed pulley from MS, has anyone got round this?
cheers
joe
Yes, but I can't remember who, think it might be mini13
Gavin Wakely did. Im not sure if there were any complications though. Give him a PM and he may be able to tell you.
Paul
Yep, I did it,
machined the back of the alternator pully down about 10mm,
will grab some pics tonight.
Mint, thanks 13
Bugger!
due to being over zellous with the locktite I can't get the pully off.
Here are some pics of the setup though.
material has been removed from the alternator side of the alternator pully, I removed as much as i thought I could getaway with, also behind the std V pully that was on there, ther was a scintered spacer washer, as the hole in the toothed pulley was bigger than the alt shaft I machined a step onto the washer to centralize the pully and took some material from this too.
You need to take as much as possible to make the pully clear the fan and rad suround. If i need any more it will need to come from lug where it mounts to the water pump which is so far untouched.
Oh also I sourced a shorter waterpump to alternator belt from a local place.
Edited by Joe C on 12th Nov, 2007.
top stuff, its a shame i have aleady trimmed the lug on the one that on, ill use the alt ive just bought off matty though so no biggy.
cheers 13
joe
If you've already trimmed the lug that'll just mean less to take off the pully.
ill have a measure up but i think ill have to take a fair bit off the pulley as there is absolutely no thread coming through at the minute, might mean the belts run quite close
another thing, did your pulley have a considerable amount of surface rust when it arrived 'new' from minispares?
