| Home > General Chat > Been thinking: Anti run-on valve - what is it's real function? | |||||||
25th Jun, 2004 at 11:01:40am
We've all called it an 'anti run-on valve'... I noticed it's reffered to as the 'carb vent valve' in Austin Rover literature however. On 17th Nov, 2014 Tom Fenton said:
25th Jun, 2004 at 01:33:25pm
Sounds feasable, it will be interesting to see what others think ?
25th Jun, 2004 at 02:27:45pm
Does make sense.
263 Posts Member #: 115 Senior Member Austria, near Vienna |
25th Jun, 2004 at 04:31:06pm
I think the valve the Metty turbo has is for venting the boiling petrol to the atmosphere. (After shutdown). We all know the starting problems 10minutes after shutdown. If all fuel evaporates there would be space for fresh cooler fuel at the next start. Never thought of that before - I think I will try to install the valve again. Maybe this cures my hotstart troubles. (Removing the bimetallic part of the jet holder did not change anything to my hotstarttroubles)
Bimmer Twinky headed and turboed A-Series:
25th Jun, 2004 at 11:16:04pm
this is interesting. mine takes for ever to start when its hot.
29th Jun, 2004 at 07:10:38pm
Fitted the carb vent valve today! Did not try a hot start, because it was raining all evening and the car is washed/clean. But what me makes worry is: The valve, when powered, becomes hot after about 5 minutes - I guess 60-70?C, a little too hot to touch! Has anyone a similar experience? The valve is open unpowered and closes when powered with +12V. Does the Metty Turbo have a "peak and hold" circuit for this valve like some modern fuel injectors work? Bimmer Twinky headed and turboed A-Series:
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
29th Jun, 2004 at 09:05:59pm
i am not sure about this valve but where i come from we use solenoid valves to keep a valve always open under power, this is a fail safe installation and the valve closes upon loss of power( wich means in practice twice a year to check the function)
29th Jun, 2004 at 09:12:10pm
Yes, it should be closed when the car is running.
29th Jun, 2004 at 09:39:44pm
replacement valves are a pneumatic component to be obtained with most pneumatic suppliers.
148 Posts Member #: 98 Advanced Member Slovenia |
30th Jun, 2004 at 07:35:09am
Harry, I use a 'anti run-on valve' for a several years. It always become hot- very hot when it is powered. but it works! i did not have any problems with it since 1998. but 'anti run-on valve' does not help me with the hot start problem. |
244 Posts Member #: 34 Senior Member |
30th Jun, 2004 at 01:35:46pm
Its a solinoid, so it will get hot during constant operation. Thats why its mounted to the bulk head to act as a heat sink.
30th Jun, 2004 at 06:23:24pm
As Arno said: Nothing to lose! I will take a suitable bolt with me to block the pipe if the solenoid fails!
