Home > Help Needed / General Tech Chat > steering UJs
andywaller
Member #: 1826
Maldon Essex
i need a bit of advice please.
my steering column is going to need a couple of universal joint in it to get it to the correct angle.
im just wondering if anyone has used something like this before, and will they be up to the job.
or has anyone used anythng else with good results?
cheers
mini93
Member #: 2017
Warwick.
i cant see why they shoudlnt work, as long as both 1/2's of the steering colomn are held in there correct working positions should be up to the job, at college we had nylon bush's made up which were snug into a circlular mount then obviously a nice bit of free movment on the internal diamiter which the colomn sat
David.
Look good and should be up for the job.
Got same on my gear lincage but paid a lot more than that
graemec
Member #: 1424
Carnforth, Lancs
Not measured the steering column but 19mm ID sounds big?
You can get the correct UK's for the splines - Mk2 escort i believe?
Edited by turbodave16v on 12th Nov, 2007.
andywaller
Member #: 1826
Maldon Essex
cheers for the replies.
i have cut the splined part off alreay and to get to the correct angle im going to need 2!
i think i will email them and see if i can get a deal!
