| Home > Help Needed / General Tech Chat > Another smoke question | |||||||
158 Posts Member #: 551 Advanced Member Ashington W.Sussex |
12th Nov, 2007 at 01:46:39pm
Hi all
12th Nov, 2007 at 02:00:18pm
is it me or does this not make any sence?
12th Nov, 2007 at 02:16:00pm
Can you explain why it doesn't make sense. No smoke from breathers or rocker cover! Engine is all new and runs fine/smooth. Turbo is stock T3 but has never been touched, came off a metro with 43,000 miles on it, no play in shaft but i'm guessing it needs a service kit. I'm in West Sussex between Horsham and Worthing. |
12th Nov, 2007 at 02:57:06pm
i'm guessing that the turbo to manifold gasket is shot so on start-up it comes out there first, but when running it tends to follow the gas path through the exhaust. |
12th Nov, 2007 at 03:18:02pm
horsham is about 1/2hr for me so if you do need help just PM me.
12th Nov, 2007 at 03:39:16pm
Iain - Maybe, but i'm thinking that because i also get large smoke from exhaust at the same time that it's more likely to be the turbo??
12th Nov, 2007 at 04:21:23pm
i was thinking kinked oil drain hose as the most probable reason for a smokey turbo sinse you say it has no play.
12th Nov, 2007 at 04:38:12pm
i was going for the whole cause Rich, more just the reason why you get some out around the turbo |
12th Nov, 2007 at 10:42:22pm
turbo seals
