| Home > Technical Chat > How valid would this be | |||||||
13th Nov, 2007 at 01:08:11pm
After reading about rocker ratios and cams for turbo use, I got to thinking how I might find a way to make a decision on what might be the optimum valve lift.
13th Nov, 2007 at 01:26:51pm
Sounds like a decent idea, theres probably some complicated mathematical equation to work it out. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
13th Nov, 2007 at 01:31:27pm
Usually the formula Valve diameter/4 is quoted as the optimum, but for a forced induction this may not apply.
13th Nov, 2007 at 01:58:31pm
The valve will lift right out of the way due to the airflow before the pressure is reached.
13th Nov, 2007 at 03:02:35pm
The optimum valve lift is the lift at which you cannot achieve any more air flow if you lift it higher.
13th Nov, 2007 at 03:05:22pm
PS I'm sitting here running some complex hydraulic modelling software, so I'm in da groove this afternoon! Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
3596 Posts Member #: 655 Post Whore Northern Ireland |
14th Nov, 2007 at 01:36:39am
Run as much as your cam, follewers, pushrods and springs can reliably handle.
591 Posts Member #: 360 Stu from Corwall aka Mr Jazz Piano, Love_Machine, kneegrow |
27th Nov, 2007 at 06:42:37pm
remember to rig up the exhausts the wrong way around. They are not inlets!
Bugger off, I'm getting there. |
