| Home > General Chat > GTM Coupe | |||||||
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
13th Nov, 2007 at 07:25:48pm
Does anyone know whether or not a turbo engine with mirage manifolds will fit into a GTM Coupe? and what issues might i run into if this were possible? It would need a scoop of some kind for an intercooler.
2645 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
13th Nov, 2007 at 07:56:18pm
There was a chap on here wh was doing one, not sure if it was a gtm or a midas tho? think his name was ethel?
Edited by shane on 13th Nov, 2007. |
13th Nov, 2007 at 08:12:31pm
thanks shane. I did a seach and that was a midas. I'm just wandering if it's been done before without major surgery.
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
13th Nov, 2007 at 08:15:24pm
I have a very early GTM with one fitted, & I've seen quite a few GTM & GTM coupe's, so yes it will fit, but depending wether or not you don't mind cutting into part of the boot area (this may depend aswell on which model / year the car is !) Also the engine cover will need modifying for the carb.
13th Nov, 2007 at 08:19:56pm
thanks Gavin that very helpful. I see I may have to do some mods if I get one, but that not too much of a problem.
Edited by Leonard on 13th Nov, 2007.
13th Nov, 2007 at 08:57:04pm
Again it depends on which type you've got, as the early ones have a monocoque chassis and some have frame work holding the rear subrame in place, but it is possible to take the engine out of the top, but you will need to remove alot of stuff and a lot of agro. I would make it so it could come out of the bottom.
On 13th of Nov, 2007 at 08:19pm Leonard said:
thanks Gavin that very helpful. I see I may have to do some mods if I get one, but that not too much of a problem. Oh another thing is it hard to remove the engine out of the top? As it may need a few rebuilds along the way! http://i28.photobucket.com/albums/c248/spe...er1/mini007.jpg
13th Nov, 2007 at 09:23:51pm
Dont be put off by cutting and having to modify fibreglass, I was very dubious when I started my minus but after you get stuck in, and as long as you take your time, fibreglass work is easy.
13th Nov, 2007 at 09:39:40pm
Get it done , GTM coupe sounds good .
![]() 168 Posts Member #: 1772 Advanced Member Leicestersheershire |
14th Nov, 2007 at 08:15:18am
On 13th of Nov, 2007 at 09:39pm cossierick said:
Get it done , GTM coupe sounds good . Rick And yes, coupes are good
Tim Rowe
14th Nov, 2007 at 06:29:25pm
thanks for the encouraging comments. Tim, I'm looking for one that's running as I don't have a garage and my landlord won't be happy about a wreck on my drive. I've seen the white one on the gtm forum, but it's out of my budget unfortunately
14th Nov, 2007 at 06:58:01pm
I'd stick wanted signs on all the sites you can think of. Someone might have a Coupe that is just sat in a garage somewhere that they don't want.
Tim Rowe
14th Nov, 2007 at 08:29:42pm
yeah do it!!
14th Nov, 2007 at 08:35:22pm
On 14th of Nov, 2007 at 08:29pm Nic said:
yeah do it!! Imagine the speeds you could achieve imagine Benross's engine/gearbox in one!
