Home > Help Needed / General Tech Chat > WELDING BULKHEAD BOX
stevecoolerking
Member #: 155
my bulkhead box looks a bit flimsy a few spot welds hold it together would you run some exra weld on it ? if so along inside of box or outside ?
Seam weld the box, do not fit it as it is !!
Mines seam welded on the engine bay side.
Phil. *smiley*
jamesfawcett
Member #: 218
Bingley, West Yorkshire
nobody told me this :( Mines seam welded all arround the tabs, along the top is double because i fitted it 1/2 an inch lower for more clearance. didnt weld the actual box though :(
I decided to seam weld mine as when i opened the packet it came in through the post both the ends fell of it .....
Not very strong at all. lol *happy*
Phil. *smiley*
Nick
Member #: 154
Midlands
yeah i looked at mine and there were 6 spot welds holding it together, seam welded that and the bulkhead. also the angled bit of bulkhead you have to cut off i just cut a V out of the crossmember and bent it round then seam welded it back up as its thicker than the piece you get with the boxes.
jamesfawcett
Member #: 218
we cut out a bit of the roof off my old mini to make a piece to double that cross member bit up lol
