Home > General Chat > The basturd clamp
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Going to be doing my exhaust clamp again today. Spent another 6 hours on it last night, pissed off at the mini again!!!
Will be ok though, just couldnt tighten up one of the nut/bolts because the weld snapped, so the weld wouldnt spin against the clamp so it was loose after all the work. Ended up taking it off again, all the exhaust paste had disapeared anyawy.
Can i ask, which do people tighten first, the one nearest the bulkhead of the one nearest the engine?
Also i ran out of fuel pipe so i need another meter.
minimark
Member #: 19
newcastle
3/8 air rachet ... 30 seconds per nut , tap it with hammer to break paste seal , clamp off ... where`s the problems?????
jamesfawcett
Member #: 218
it was jammed on the block haha
fitted it now, glad i took it off it needd more paste. with both bolts welded, took about 15 minuets!!!
