| Home > Help Needed / General Tech Chat > Brake question | |||||||
69 Posts Member #: 1457 Advanced Member Bristol |
21st Nov, 2007 at 09:19:33pm
Hi all. Im currently using a standard mini set up, 2pot calipers and solid discs (8.4"). I have a set of metro 4pot callipers and vented discs which i want to convert to mine, would i be able to swap the calipers and discs straight onto my hubs etc? or would i need to change the whole driveshaft and hubs? Cheers
21st Nov, 2007 at 10:25:19pm
i think all you need is the metro drive flanges, which will need the 4 oval lugs chopping off from the centre, i think no longer a series, but still 1.3 turbo.
82 Posts Member #: 939 Advanced Member |
21st Nov, 2007 at 10:32:10pm
the lugs clear some wheels. they were perfect fit for my superlites |
21st Nov, 2007 at 10:39:31pm
As said yes your metro 4pots and discs will fit on your hubs, as bodgeit says some do clear the lugs but as far as am aware some 12" wheels wont clear the calipers tho (most do tho)
22nd Nov, 2007 at 12:12:25am
you need the metro conversion pipework too |
![]() 214 Posts Member #: 1574 Senior Member Malta |
22nd Nov, 2007 at 12:54:38pm
Agree with Nic you need the brake pipework conversion too. The lugs on the drive flange fit alomost all 13" and many 12" wheel without modifying. You HAVE to have the metro drive flange any other will not fit. You used to be able to buy modded ones at the suppliers but these are no manufactured/available.
53 Posts Member #: 2069 Advanced Member Oxfordshire |
22nd Nov, 2007 at 01:25:15pm
sorry to hijack but just out of interest, why will the mini drive flanges not fit? do the holes thet bolt it to the disk not line up or something? |
22nd Nov, 2007 at 09:31:16pm
The metro flanges move the discs out from the hub, without them the discs & callipers won't align. Isambard Kingdom Brunel said:
