| Home > Help Needed / General Tech Chat > Turbo Question | |||||||
8 Posts Member #: 2033 Junior Member |
22nd Nov, 2007 at 10:02:56pm
hi all, just wondering when you convert to turbo, if you need like a control unit ecu (Did the metro turbo have one?) or can you run without?
621 Posts Member #: 393 Post Whore Oulton Park |
22nd Nov, 2007 at 10:11:37pm
old set up coil and dizzy and two wires away you go |
22nd Nov, 2007 at 10:13:24pm
Metro's had an ECU of sorts but all it did was limit the boost below 4K. Isambard Kingdom Brunel said:
53 Posts Member #: 2069 Advanced Member Oxfordshire |
23rd Nov, 2007 at 10:24:46am
As the others said the metro turbo had an ECU that would limmit the bost to 4psi untill 4000 rpm when it would allow the turbo to boost 7psi.
