Home > Help Needed / General Tech Chat > Cleaning turbine housing
My turbine housing is a little choked up to say the least after some VERY worn oil seals.
Is it worth cleaning the excessive build up of oil out of the housing or will it just burn off once its up to temp?
If its worth doing, has anyone got any good ways of cleaning it, without having to use baths of solvents etc...?
Matt
thinners cheap as chips and does the job
of corse it will burn off mat but..... better to get shut of the gunge and save the planet ....lol
Ah cool got plenty of thinners..will give it a try tonight! :)
Cheers Steve. *wink*
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
If not that, diesel or parrifin.
but use your mums rubber gloves
(theyre in the back of her 2nd drawer in the bedside table)
PMSL *laughing* *laughing*
mini93
Member #: 2017
Warwick.
got access to a shotblaster/hand glass blaster what ever you want to call it?
at work the centre body, exhaust and inlet all go into the blaster (as long as the studs wont get caught)
we use a solvent wash to take most the oil out then put it in the blaster when it come out its fine, if you want you can always polish the insides a little (depending what turbo it is, KKK ones have removable insides)
we also make sure that all the shot is out the turbo, nothing a good bit of compressed air wont solve...health n safety love that bit!
David.
