Home > General Chat > Megajolt - Yet again
chris4500uk
Member #: 2097
Middlesbrough
I'm very intrested in a megajolt kit for my 998cc turbo
I'm read most of the previous posts, I am right in thinking I only need the megajolt ecu and a boost line/manifold vac line with a crack sensor, oh and the trigger wheel ?
Who is activlely still selling custom mini made trigger wheels? Or pulley as I cannot weld *tongue*
You'll need the Megajolt unit (MAP version), a 36 tooth trigger wheel, Vr sensor bracket.
And from a Ford you'll need, VR sensor, Edis module, coil pack, and leads.
Oh yeah you'll also need a blanking plate for the dizzy. *wink*
I think Roger is still doing the pulleys although I haven't seen him on here for a while?
Nic has written a good guide to fitting this, it also has a list of the parts needed.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=5741
KAD do a trigger wheel kit for a little over £100 on ebay.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
hopefully in the next few weeks I'll have some more pulleys in stock.
AlexF
