| Home > Help Needed / General Tech Chat > Alloy welding | |||||||
29th Nov, 2007 at 11:07:14am
Hi, I've just bought a perfect sized intercooler for my steel front, round nose mini. The problem is, the inlet and outlet's are straight.
Edited by theoneeyedlizard on 29th Nov, 2007. In the 13's at last!.. Just |
29th Nov, 2007 at 01:41:56pm
Couldnt you just use a 90 degree silicone hose on each end, would prob give you more room too :) |
29th Nov, 2007 at 01:46:07pm
That's option 2, but I don't think that I will have enough clearance without cutting the inner wings.
29th Nov, 2007 at 02:39:06pm
http://www.owensfabrication.com/ On 17th Nov, 2014 Tom Fenton said:
29th Nov, 2007 at 02:53:00pm
i have the same cooler, see pic to the left.. its big! you sure it will fit in??? |
29th Nov, 2007 at 03:01:11pm
Cheers Dave, I've just called Endaf.
29th Nov, 2007 at 03:01:32pm
It's not the same as that Mark. It's only about 560mm wide and 160mm deep including the end tanks. It fits in the standard space behind the grille with no modifications except the hose fittings.
29th Nov, 2007 at 03:08:12pm
I'll get some pics up tomorrow,
29th Nov, 2007 at 03:20:08pm
On 29th of Nov, 2007 at 03:01pm theoneeyedlizard said:
It's not the same as that Mark. It's only about 560mm wide and 160mm deep including the end tanks. It fits in the standard space behind the grille with no modifications except the hose fittings. It's nice and deep (90mm) so should do the job well! oh right.. should squeeze in then! when mine came in the post i was worried it woudnt fit under my clubby flip!
